Using an Array to assign values to another array
Hey all!
I took a long hiatus from electronics and am having a bit of trouble finding a way to take data from one long array and breaking it into smaller arrays for an RFID reader code I want to write. It is supposed to compress alot of different separate codes into a single code so I can have a more versatile platform to use when working with RFID cards. Otherwise i will spend half my time uploading the codes over and over. So please just bare with the awful awful code below. Essentially I am sending a bunch of variables over a single message through serial and need to break it into parts. I can do it with the single digit variables but my issue is lying in how to send the actual messages. This is what I thought of but it could just be garbage:
Basically all I want to do is type in "initialize [int] [int] [16 character message]" the 1st int will tell it the specific command, the 2nd int being the block and the 16 character message being what is written on the block, I cannot seem to break off the 16 character message as it's own array from the original 28 one
(completely forgot how to insert code into a separate window so I shortened it)
int a = 0;
int i = 0;
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// say what you got:
Serial.print("I received: ");
Serial.println(incomingByte, DEC);
statement = incomingByte;
  • i++;*
  • int x = statement[11];*
  • int y = statement [0];*
  • int z = statement [1];*
  • int zz = statement [2];*
  • if (x != 0 && y == 105 && z == 110 && zz == y) {*
  • Serial.print("I have decided: ");*
  • Serial.println(x);*
    //^^ this checks to see if the first three letters match the command I want (I know its not super accurate but whatever)
  • if (x == 49) {*
  • Serial.print("Card Rewrite Selected for Block: ");*
  • int block = statement[13];*
  • Serial.println(block);*
    //This section divines the desired block by looking at the number following the "Initialize"
  • for (i = 14; i < 29; i++) {*
  • int a = i-14;*
    _ byte blockcontent[a] = statement*;_
    _
    }_
    _
    Serial.print("Message Received To Be: ")_
    _
    Serial.println(blockcontent[]);_
    _
    //This section is the problem as I cannot compile because it says the array must be initialize with a brace enclosed initializer*_
Go read the stickies at the top of the forum, and remember, because I KNOW your code doesn't look like that.
It does not make sense to try to parse the data after adding each character to the String. You ONLY parse the data when you have ALL of it.
