Hey! I am using an MPU6050 and want to stop the NEMA 17 Steppermotor when there is any sudden acceleration in any direction - x,y, or z. I am having trouble getting the slope and the resultant to work to detect this rapid change
Here is some code to start:
Accelerometer code - Automatic shutoff of NEMA 17 Stepper Motor
April 1, 2024
#include <MPU6050_tockn.h> // Include the MPU6050 library
#include <Wire.h> // Include the Wire library for I2C communication
MPU6050 mpu6050(Wire); // Initialize the MPU6050 object with the Wire library
const int dirPin = 3; // Define the pin for stepper motor direction control
const int stepPin = 4; // Define the pin for stepper motor step control
const int buttonPin = 13; // Define the pin for the pushbutton
const int stepsPerRevolution = 200; // Define the number of steps per revolution for the stepper motor
long timer = 0; // Initialize a variable to store the current time
float prevAccX = 0; // Initialize a variable to store the previous X-axis acceleration
float prevAccY = 0; // Initialize a variable to store the previous Y-axis acceleration
float prevAccZ = 0; // Initialize a variable to store the previous Z-axis acceleration
bool rapidChangeDetected = false; // Initialize a flag to indicate if a rapid change in acceleration is detected
Serial.begin(9600); // Start serial communication at 9600 baud rate
Wire.begin(); // Initialize the I2C communication
mpu6050.begin(); // Initialize the MPU6050 sensor
mpu6050.calcGyroOffsets(true); // Calibrate the gyroscope offsets
pinMode(buttonPin, INPUT); // Set the button pin as input
pinMode(stepPin, OUTPUT); // Set the step pin for the stepper motor as output
pinMode(dirPin, OUTPUT); // Set the direction pin for the stepper motor as output
mpu6050.update(); // Update MPU6050 sensor readings
// Read acceleration values
float accX = mpu6050.getAccX(); // Read X-axis acceleration
float accY = mpu6050.getAccY(); // Read Y-axis acceleration
float accZ = mpu6050.getAccZ(); // Read Z-axis acceleration
Serial.println("=======================================================");
Serial.print("temp : ");Serial.println(mpu6050.getTemp());
Serial.print("accX : ");Serial.print(mpu6050.getAccX());
Serial.print("\taccY : ");Serial.print(mpu6050.getAccY());
Serial.print("\taccZ : ");Serial.println(mpu6050.getAccZ());
// Check for rapid change in acceleration
if (millis() - timer > 1000) { // Check if it's time to check for a rapid change
float deltaX = abs(accX - prevAccX); // Calculate change in X-axis acceleration
float deltaY = abs(accY - prevAccY); // Calculate change in Y-axis acceleration
float deltaZ = abs(accZ - prevAccZ); // Calculate change in Z-axis acceleration
float deltaAcc = sqrt(deltaX * deltaX + deltaY * deltaY + deltaZ * deltaZ); // Calculate total change in acceleration
if (deltaAcc > 0.3) { // Check if rapid change in acceleration exceeds threshold
rapidChangeDetected = true; // Set flag to indicate rapid change detected
float timeDiff = (millis() - timer) / 1000.0; // Calculate time difference since last check
float slope = deltaAcc / timeDiff; // Calculate slope of acceleration change
Serial.print("Slope: "); // Print slope to serial monitor
Serial.println(slope);
prevAccX = accX; // Update previous X-axis acceleration
prevAccY = accY; // Update previous Y-axis acceleration
prevAccZ = accZ; // Update previous Z-axis acceleration
timer = millis(); // Update timer to current time
// Set motor direction clockwise
digitalWrite(dirPin, HIGH); // Set direction pin to control motor direction
// Read button state
int buttonState = digitalRead(buttonPin); // Read state of pushbutton
// Rotate motor if button is pressed and no rapid change detected
if (buttonState == LOW ) { // Check if button is pressed and no rapid change detected
for (int i = 0; i < stepsPerRevolution &&rapidChangeDetected; i++) { // Loop for specified number of steps per revolution
digitalWrite(stepPin, HIGH); // Set step pin to high to trigger a step
delayMicroseconds(450); // Delay to control step timing
digitalWrite(stepPin, LOW); // Set step pin back to low
if (buttonState == HIGH) // if button is not pressed, turn the motor off
} else { // Stop motor if rapid change detected
digitalWrite(stepPin, LOW); // Set step pin low to stop the motor
rapidChangeDetected = false; // Reset the flag
