Using an SD card to store a high score or high value into a variable
Hey folks, I've got reading from and writing to my SD card down fine. However, I'm struggling with something pretty simple. I have created a highscore.txt file on my SD card that contains literally one integer. I want to read that integer on the file on the SD card into a variable in my code. I've tried a number of different options and can't seem to make it work. I am a novice, but I think in Python/Pygame the command is as simple as
highscore = int([filename].read())
I've used this command when designing games in pygame, and it works fine.
is there something similarly simple for the arduino IDE?
Thanks.
(deleted)
@ashamim
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Thanks for your reply Peter.
Yes, I did check SD library and didn't see anything directly helpful. Did I miss something?
PS NOTE TO MODERATOR: apologies for duplicate post
ashamim:
Thanks.
By definition a "text" file only contains 7 bit ASCII characters. Putting a 16 bit binary value (integer) into a text file will cause unknown failures.
Paul
