Using an Ultrasonic Sensor to start a timer
Hey, so my Capstone group is working on our prototype and we're stuck on how to get the ultrasonic sensor to start a timer. We believe it's a coding issue so if anyone can help us troubleshoot our code it would be much appreciated.
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
long cm = 0;
String lightColor = "green";
int ledpinG= 8 ; // the number of the LED pin
int ledpinR= 10 ; // the number of the LED pin
long readUltrasonicDistance(int triggerPin, int echoPin)
pinMode(triggerPin, OUTPUT); // Clear the trigger
digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
// Sets the trigger pin to HIGH state for 10 microseconds
digitalWrite(triggerPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
// Reads the echo pin, and returns the sound wave travel time in microseconds *0.01723
return (pulseIn(echoPin, HIGH)*0.01723);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.clear ();
// Print a message to the LCD.
lcd.print("Start");
// initialize the led pin as an output:
pinMode(ledpinR, OUTPUT);
pinMode(ledpinG, OUTPUT);
double i = 0;
double a = millis ();
double c;
int min=0;
int hours=0;
cm =readUltrasonicDistance(12,11);
Serial.print(cm);
Serial.println("cm");
//reads the object detected distance. If detected, light green
if (cm <= 300) {
digitalWrite(ledpinR, LOW);
digitalWrite(ledpinG, HIGH);
//Serial.print("green");
else if (cm>=30){
else if (cm>300){
digitalWrite(ledpinR, HIGH);
digitalWrite(ledpinG, LOW);
//no object detected - light red
else {
lightColor = "red";
delay(1); // Wait for 100 millisecond(s)
lcd.clear ();
lcd.print ("Press start");
delay (10);
if (lightColor == "red")
    lcd.clear ();
    a = millis ();
    while (lightColor == "red")
        c = millis ();
        i = (c - a)/1000;
      if(i==60)
         a = millis ();
         c = millis ();
         i=0;
        min++;
        if(min==60)
        min=0;
        lcd.print(min);
        lcd.print(':');
        lcd.print (i);
        lcd.setCursor (10, 2);
        lcd.print ("Sec's");
        lcd.setCursor (0, 0);
        //Serial.println (c);
        //Serial.println (a);
        //Serial.println (i);
        //Serial.println ("......");
        delay (1);
   if (lightColor == "green")
            lcd.print (i);
            lcd.setCursor (11, 0);
            lcd.print ("");
            delay (1);
You have if (cm <= 300) { . . .
When will else if (cm>=30){ execute ?
You have: if (cm <= 300) { . . .
Then you have: else if (cm>300){ . . .
Will this ever execute ?
else { . . .
Hi, @solis22
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
This will help with advice on how to present your code and problems.
Have you looked at NewPing library, it will do all the necessary processes to get a distance reading.
Look at the examples;
https://playground.arduino.cc/Code/NewPing/
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
Thank you, the NewPing library helped us make the ultrasonic sensor work.
