using analog inputs with digital inputs
Im using a standard analog input and PWM output program. Im using a temperature transmitter to control a PWM output to control a cooling fan. The problem is I need the fan to go full speed when air-conditioning is on and cant get it to work. Here is the analog program I'm using. HELP!
const int analogInPin = A0;
const int analogOutPin = 9;
int sensorValue = 0;
int outputValue = 0;
sensorValue = analogRead(analogInPin);
outputValue = map(sensorValue, 0, 1023, 0, 255);
analogWrite(analogOutPin, outputValue);
Serial.print("sensor = ");
Serial.print(sensorValue);
Serial.print("\t output = ");
Serial.println(outputValue);
delay(2);
please post within </> code-tags.
what is the output in the serial monitor ?
how do you tell the Arduino the airconditioner is on ?
how have you wired things up ?
outputValue = sensorValue / 4;
You don't seem to call pinMode( analogOutPin, OUTPUT ) during setup().
Blackfin:
You don’t seem to call pinMode( analogOutPin, OUTPUT ) during setup().
analogWrite does that for you.
Blackfin:
Figure-1: Pre-defined PWM signals for analogWrite() function
When user executes the following codes, the indicated DPins automatically configured as output lines and convey PWM signals of the specified frequency (Fig-1).
analogWrite(3, dutyCycle);     //490 Hz PWM signal at DPin-3
analogWrite(11, dutyCycle);   //490 Hz PWM signal at DPin-11
analogWrite(10, dutyCycle);     //490 Hz PWM signal at DPin-10
analogWrite(9, dutyCycle);     //490 Hz PWM signal at DPin-9
analogWrite(5, dutyCycle);     //980 Hz PWM signal at DPin-5
analogWrite(6, dutyCycle);     //980 Hz PWM signal at DPin-6
