Using analog output of Sharp IR sensor directly with Due
He guys, I have been searching for a while now, but I can't find a good answer.
The Sharp IR sensor works on 5V supply. The analog output signal is supposedly up to "3.1V" when the distance is 10cm.
But we know that this sensor produces noisy data. So is it safe to connect the analog output to the analog in pin of a Due (which takes up to 3.3V only), or would the sensor possibly produce voltage spikes higher than 3.3V on its output?
