I have a couple questions about using analogReference on an Pro Mini 3.3volts.
If I set the reference to 1.1volts with analogReference(INTERNAL), I assume it's till okay to have the actual voltage on the pins go up to 3.3 volts. Is that correct?
Can I change the analogReference before I read an input, then change it back to read a different input. Any issues with doing this. For example:
ScottG:
Yes, electrically no problem, however all values above 1.1vdc will read as 1023 counts.
**Yes in theory it will work, but I've found that a analogRead() right after a change in analogReference() will usually return a 'faulty' value. I've usually do a couple of analogReads on the same pin after such a reference change and the last reading tends to be OK. You may have to play around with it to see what you get.**
**Lefty**
