Hi everyone, I am trying to onboard a device on AWS IOT. The process is that you start with default certificates, you onboard and receive now ones, then you can use them. This is arduino on ESP32, but I struggle with the char arrays and copies...
So I need to:
- store a string in a JSON document (a default certificate)
- Save that JSON to file
then later: - Load the string, and onboard my device which will then receive its final certificate
- change the certificate string with that new value
- Save to file again to keep the new certi hardcoded.
My first issue: saving the default certificate. In the code below I have tried different formats
char* AWS_CERT_CA = \
"-----BEGIN CERTIFICATE-----\n" \
"5MsI+yMRQ+h.....................K642M4UwtBV8ob2xJNDd2ZhwLnoQdeXeGADbkpy\n" \
"rqXRfboQnoZsG4q5WTP468SQvvG5\n" \
"-----END CERTIFICATE-----\n";
(and same for AWS_CERT_CRT and AWS_CERT_PRIVATE)
const int capacity = 100 + JSON_OBJECT_SIZE(3);
StaticJsonDocument<capacity> doc;
File file;
//Save to file
file = SPIFFS.open(certs, "w+"); //Create file
doc["AWS_CERT_CA"] = *AWS_CERT_CA;
doc["AWS_CERT_CRT"] = (char*)AWS_CERT_CRT;
doc["AWS_CERT_PRIVATE"] = "*AWS_CERT_PRIVATE";
if (serializeJson(doc, file) == 0) {
Serial.println(F("Failed to write to file"));
} else Serial.println("file written");
file.close();
When I print the resulting file, it gives that result:
10:06:18.031 -> Load certificates from file
10:06:18.031 -> {"AWS_CERT_CA":45,"AWS_CERT_CRT":null,"AWS_CERT_PRIVATE":"*AWS_CERT_PRIVATE"}
How can I write the certificate correctly?
