I have developed an Android app that controls some relays via bluetooth to a nano. It has been working quite happily for four years but, it uses delay built into the app. I'm redesigning the app and having the delay in the app is now giving some problems. Here is the code that works using the app delay. Not shown are 6 more relays that are simply on/off.
char data = 0;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
if (Serial.available() > 0)
data = Serial.read();
Serial.print(data);
Serial.print("\n");
//----------------------------------3
//door lock-------------
if (data == 'E')
digitalWrite(2, LOW);
//delay 3.5 seconds 3500 built into the app
else if (data == 'F')//App uses this command to set 2 high
//----------------------------------4
//door unlock-------------
if (data == 'G')
digitalWrite(3, LOW);
else if (data == 'H')//App uses this command to set 3 high
As usual I've looked at all I can find on the subject of using millis and don't seem to find quite what I am looking for. I need the pin to stay LOW for a period of time after the arduino gets the bluetooth signal to go low then go HIGH until requested again.
I thought this would do it. Not only does it not work, none of the other 6 relays work and I get a broken pipe error.
unsigned long startMillis;
unsigned long currentMillis;
unsigned long currentTime = millis();
unsigned long prevTime_T1 = millis();
unsigned long prevTime_T4 = millis();
long interval_T1 = 3000; // reset door lock relay
long interval_T4 = 3000; //reset door unlock relay
char data = 0;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
startMillis = millis(); //initial start time
Serial.print(data);
Serial.print("\n");
if (data == 'E')
if (currentTime - prevTime_T1 > interval_T1)
prevTime_T1 = currentTime;
if (data == 'G')
if (currentTime - prevTime_T4 > interval_T4)
prevTime_T4 = currentTime;
Thanks for looking
