Hi everyone,
I am trying to monitor and control the output of a buck converter with PMBus protocol in Arduino Uno.
I read different post and article, and used some codes in Arduino FORUM, but almost all does not work.
Finally, I tried to remove errors in a code, but still there is an error ''undefined reference to linear16(unsigned char, unsigned char)'.'' and ''undefined reference to linear11(unsigned char, unsigned char)'.''
I put the whole code here.
Please help me.
Thanks in advance.
#include <Wire.h>`Preformatted text`
#include <float.h>`Preformatted text`
/* Address */
const byte VCCINT = 0x38`Preformatted text`;
/* Command */
const byte VIN = 0x88;
const byte VOUT = 0x8B;
const byte IOUT = 0x8C;
const byte PW = 0x96;
/* Register values */
double Vo = 0;
double Vi = 0;
double Io = 0;
double P = 0;
/* Function Prototype */
double ByteRequest(byte DeviceAddr, byte Command, int format); // format : 0 linear11, 1 linear16
double linear11(byte msb, byte lsb);
double linear16(byte msb, byte lsb);
Wire.begin();
Wire.setClock(100000L);
Serial.println("~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~");
Vo = ByteRequest(VCCINT, VIN, 0);
Serial.print("Vin = ");
Serial.print(Vo);
Serial.println(" V");
Vi = ByteRequest(VCCINT, VOUT, 1);
Serial.print("Vout = ");
Serial.print(Vi);
Io = ByteRequest(VCCINT, IOUT, 0);
Serial.print("Iout = ");
Serial.print(Io);
Serial.println(" A");
P = ByteRequest(VCCINT, PW, 0);
Serial.print("Power = ");
Serial.print(P);
Serial.println(" W");
delay(2000);
// convert a LinearFloat5_11 formatted word into a floating point value
float linear11ToFloat(uint16_t wordValue)
int8_t exponent = wordValue>>11; // extract exponent as MS 5 b its
int16_t mantissa = wordValue & 0x7ff; // extract mantissa as LS 11 bits
if ( exponent > 0x0F ) exponent |= 0xE0; // sign extend exponent
if ( mantissa > 0x03FF ) mantissa |= 0xF800; // sign extend mantissa
return mantissa * pow(2,exponent); // compute value as
// mantissa * 2^(exponent)
float linear16ToFloat(uint8_t exp,uint16_t wordValue)
int8_t exponent = exp; // extract exponent as MS 5 b its
int16_t mantissa = wordValue; // extract mantissa as LS 11 bits
double ByteRequest(byte DeviceAddr, byte Command, int format){
byte ReceiveData = 0x00;
int wen = 0;
byte msb = 0;
byte lsb = 0;
double res = 0;
Wire.beginTransmission(DeviceAddr);
Wire.write(Command);
wen = Wire.endTransmission((uint8_t) false);
if (wen != 0) {
Serial.print("endTransmission error ");
Serial.println(wen);
Wire.requestFrom((uint8_t) DeviceAddr, (uint8_t) 2, (uint8_t) true);
if (Wire.available()) {
lsb = Wire.read();
msb = Wire.read();
Serial.println("No data on bus\r\n");
if(format==1)
res = linear16(msb,lsb);
res = linear11(msb,lsb);
wen = Wire.endTransmission((uint8_t) true);
return res;
