I am trying to find a light chase to connect three light boxes. The boxes are set up with LEDs and each has its own transformer. The client would like each light box to illuminate independently for seconds in sequence.
Which Arduino product would be suitable for this application?
If the boxes should not be tempered with or hacked, you should try the power switch tail and control each led box with one such switch. You can't dim the LEDs this way. It's only on/off. Any arduino such as UNO will work.
No problem! If you can [u]blink[/u] one LED you can blink 3 LEDs in sequence. And of course, you can control something else besides one LED per output.
If you are going to switch the AC power, you'll need a relay or a solid state relay (or the Power Tail liudr suggested) A relay allows you to control a high voltage & current with a lower voltage, and it provides electrical isolation between the Arduino (and you!) and the lethal voltages.
Solid state relays are easier to use than electro-mechanical relays, but they are more expensive. Get solid state relays that use 5V on the input-side and are rated to control AC voltage & current equal to or greater than your AC load.
If you get a regular electro-mechanical relay you'll probably need a relay driver circuit to boost the current & voltage to the relay coil and you may need to provide 12V for the relay coil. (You can buy relay boards with multiple relays and drivers installed.)
...But before you start, plug the light boxes into a switched power outlet and make sure the LEDs switch on & off quickly and "cleanly" without flickering or anything. Since there is a power supply you didn't build, you can't be sure how it will behave when switched rapidly.
I can access the interior of the boxes and wired the LEDs together myself. I just want the lights to blink on and off they do not need to dim.
So it sounds like I can accomplish this with the Arduino Uno, but then I also need the relay - do I plug the relay into the power source, and then plug the Arduino into that, and then the light boxes to the Aurduino? Can I use one relay for all of them or does each light box need a relay? (that seems a little over complicated and expensive). Just trying to figure out the easiest way to make them blink at the desired interval
I'm using a standard strip of bright white LEDs, each with their own transformer.
I want to set the timing for the lights to a specific interval but don't necessarily need to change it after that. This is the first time I've attempted this so I'm just looking for simplest and most cost effective solution - any advice is very welcome!!!
" The boxes are set up with LEDs and each has its own transformer"
Its own transformer, means its own power? What power is needed to turn the box on/off?
If it is just a 5Volt signal, then the arduino can provide that voltage (without a relay).
LKlenow:
There's no such thing as a "standard strip of bright white LEDs".
It would be good to know how much current the LEDs required.
I think the previously mentioned relays would work. Electromechanical relays will likely require a transistor, a resistor and a diode to interface with an Arduino. Electromechanical are less expensive than solid state relays (SSR). A SSR has several advantages. One is it doesn't require extra parts and can be driven directly by an Arduino. Another advantage of SSRs is they're quiet. SSR don't click when they're turned on and off. SSR often last longer (this has been my experience).
The downside to using SSR is the price. They're generally more expensive than the electromechanical kind.
To switch a AC load, you need to make sure and get a SSR made for AC. SSR are generally made for either AC or DC, not both.
It would be good to know how much current the LEDs will draw so an appropriate relay can be selected.
