Hey,
I am also doing a project similar to yours. I am trying to hook up an accelerometer and have it communicate with max/msp to create music. Perhaps you or somebody could help me out…
I have the code that reads information from my accelerometer
const int groundpin = 18; // analog input pin 4 -- ground
const int powerpin = 19; // analog input pin 5 -- voltage
const int xpin = A3; // x-axis of the accelerometer
const int ypin = A2; // y-axis
const int zpin = A1; // z-axis (only on 3-axis models)
// initialize the serial communications:
// Provide ground and power by using the analog inputs as normal
// digital pins. This makes it possible to directly connect the
// breakout board to the Arduino. If you use the normal 5V and
// GND pins on the Arduino, you can remove these lines.
pinMode(groundpin, OUTPUT);
pinMode(powerpin, OUTPUT);
digitalWrite(groundpin, LOW);
digitalWrite(powerpin, HIGH);
// print the sensor values:
Serial.print(analogRead(xpin));
// print a tab between values:
Serial.print("\t");
Serial.print(analogRead(ypin));
Serial.print("\t");
Serial.print(analogRead(zpin));
// delay before next reading:
delay(100);
I also have the Standard Firmata Code that lets my Arduino communicate with Max/msp.
#include <Firmata.h>
#include <Servo.h>
* GLOBAL VARIABLES
/* analog inputs */
int analogInputsToReport = 0; // bitwise array to store pin reporting
int analogPin = 0; // counter for reading analog pins
/* digital pins */
byte reportPINs[TOTAL_PORTS]; // PIN == input port
byte previousPINs[TOTAL_PORTS]; // PIN == input port
byte pinStatus[TOTAL_DIGITAL_PINS]; // store pin status, default OUTPUT
byte portStatus[TOTAL_PORTS];
/* timer variables */
unsigned long currentMillis; // store the current value from millis()
unsigned long nextExecuteMillis; // for comparison with currentMillis
int samplingInterval = 19; // how often to run the main loop (in ms)
Servo servos[MAX_SERVOS];
* FUNCTIONS
void outputPort(byte portNumber, byte portValue)
portValue = portValue &~ portStatus[portNumber];
if(previousPINs[portNumber] != portValue) {
Firmata.sendDigitalPort(portNumber, portValue);
previousPINs[portNumber] = portValue;
* check all the active digital inputs for change of state, then add any events
* to the Serial output queue using Serial.print() */
void checkDigitalInputs(void)
byte i, tmp;
for(i=0; i < TOTAL_PORTS; i++) {
if(reportPINs[i]) {
switch(i) {
case 0:
outputPort(0, PIND &~ B00000011); // ignore Rx/Tx 0/1
case 1:
outputPort(1, PINB);
case ANALOG_PORT:
outputPort(ANALOG_PORT, PINC);
/* sets the pin mode to the correct state and sets the relevant bits in the
* two bit-arrays that track Digital I/O and PWM status
void setPinModeCallback(byte pin, int mode) {
byte port = 0;
byte offset = 0;
// TODO: abstract for different boards
if (pin < 8) {
port = 0;
offset = 0;
} else if (pin < 14) {
port = 1;
offset = 8;
} else if (pin < 22) {
port = 2;
offset = 14;
if(pin > 1) { // ignore RxTx (pins 0 and 1)
if (isServoSupportedPin(pin) && mode != SERVO)
if (servos[pin - FIRST_SERVO_PIN].attached())
servos[pin - FIRST_SERVO_PIN].detach();
if(pin > 13)
reportAnalogCallback(pin - 14, mode == ANALOG ? 1 : 0); // turn on/off reporting
switch(mode) {
case ANALOG:
digitalWrite(pin, LOW); // disable internal pull-ups and fall thru to 'case INPUT:'
case INPUT:
pinStatus[pin] = mode;
pinMode(pin, INPUT);
portStatus[port] = portStatus[port] &~ (1 << (pin - offset));
case OUTPUT:
digitalWrite(pin, LOW); // disable PWM and fall thru to 'case PWM:'
case PWM:
pinMode(pin, OUTPUT);
portStatus[port] = portStatus[port] | (1 << (pin - offset));
case SERVO:
// TODO: Support Arduino Mega
if (isServoSupportedPin(pin)) {
if (!servos[pin - FIRST_SERVO_PIN].attached())
servos[pin - FIRST_SERVO_PIN].attach(pin);
} else
Firmata.sendString("Servo only on pins from 2 to 13");
case I2C:
Firmata.sendString("I2C mode not yet supported");
default:
Firmata.sendString("Unknown pin mode"); // TODO: put error msgs in EEPROM
// TODO: save status to EEPROM here, if changed
void analogWriteCallback(byte pin, int value)
switch(pinStatus[pin]) {
case SERVO:
servos[pin - FIRST_SERVO_PIN].write(value);
case PWM:
analogWrite(pin, value);
void digitalWriteCallback(byte port, int value)
switch(port) {
case 0: // pins 2-7 (don't change Rx/Tx, pins 0 and 1)
// 0xFF03 == B1111111100000011 0x03 == B00000011
PORTD = (value &~ 0xFF03) | (PORTD & 0x03);
case 1: // pins 8-13 (14,15 are disabled for the crystal)
PORTB = (byte)value;
case 2: // analog pins used as digital
byte pin;
byte pinModeMask;
for(pin=0; pin<8; pin++)
if(pinStatus[pin] == OUTPUT)
pinModeMask += 1 << pin;
PORTC = (byte)value & pinModeMask;
/* sets bits in a bit array (int) to toggle the reporting of the analogIns
//void FirmataClass::setAnalogPinReporting(byte pin, byte state) {
void reportAnalogCallback(byte pin, int value)
if(value == 0) {
analogInputsToReport = analogInputsToReport &~ (1 << pin);
else { // everything but 0 enables reporting of that pin
analogInputsToReport = analogInputsToReport | (1 << pin);
void reportDigitalCallback(byte port, int value)
reportPINs[port] = (byte)value;
if(port == ANALOG_PORT) // turn off analog reporting when used as digital
* SYSEX-BASED commands
void sysexCallback(byte command, byte argc, byte *argv)
switch(command) {
case SERVO_CONFIG:
if(argc > 4) {
// these vars are here for clarity, they'll optimized away by the compiler
byte pin = argv[0];
int minPulse = argv[1] + (argv[2] << 7);
int maxPulse = argv[3] + (argv[4] << 7);
// servos are pins from 2 to 13, so offset for array
servos[pin - FIRST_SERVO_PIN].attach(pin, minPulse, maxPulse);
setPinModeCallback(pin, SERVO);
case SAMPLING_INTERVAL:
if (argc > 1)
samplingInterval = argv[0] + (argv[1] << 7);
Firmata.sendString("Not enough data");
boolean isServoSupportedPin(byte pin)
return ((FIRST_SERVO_PIN <= pin) && (pin <= (FIRST_SERVO_PIN + MAX_SERVOS)));
* SETUP()
byte i;
Firmata.setFirmwareVersion(2, 1);
Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
Firmata.attach(DIGITAL_MESSAGE, digitalWriteCallback);
Firmata.attach(REPORT_ANALOG, reportAnalogCallback);
Firmata.attach(REPORT_DIGITAL, reportDigitalCallback);
Firmata.attach(SET_PIN_MODE, setPinModeCallback);
Firmata.attach(START_SYSEX, sysexCallback);
portStatus[0] = B00000011; // ignore Tx/RX pins
portStatus[1] = B11000000; // ignore 14/15 pins
portStatus[2] = B00000000;
for(i=0; i < FIRST_ANALOG_PIN; ++i) {
setPinModeCallback(i,OUTPUT);
// set all outputs to 0 to make sure internal pull-up resistors are off
PORTB = 0; // pins 8-15
PORTC = 0; // analog port
PORTD = 0; // pins 0-7
// TODO rethink the init, perhaps it should report analog on default
for(i=0; i<TOTAL_PORTS; ++i) {
reportPINs[i] = false;
// TODO: load state from EEPROM here
/* send digital inputs here, if enabled, to set the initial state on the
* host computer, since once in the loop(), this firmware will only send
* digital data on change. */
if(reportPINs[0]) outputPort(0, PIND &~ B00000011); // ignore Rx/Tx 0/1
if(reportPINs[1]) outputPort(1, PINB);
if(reportPINs[ANALOG_PORT]) outputPort(ANALOG_PORT, PINC);
Firmata.begin(57600);
My question is how to I combine the two codes so that the information being recorded by the accelerometer is being sent to Max/msp?
Thanks!
Mike
