using arduino as analog input for python program
Hi, I wrote a pyhton program and I would like to use an anlog input to control it. Basically I was thinking to use 3 potentiometers to set 3 different variables and 2 buttons which would activate 2 different method. I'm quite new to arduino so I'm not very sure how to do it. which way would you reccomend me? at the moment I have an arduino Uno board by sunfounder which a friend of mine gave me. would that one be fine? can I handle 5 different analog inputs at once?
thank you very much!
Did you read the stickied post Demo of PC-Arduino comms using Python at the top of this foprum section?
Just in case, the other side for receiving from the PC is described here in detail: Serial Input Basics - updated; not sure if it's needed but makes a good reading how to approach serial communication.
That should give you enough ammunition.
