Using Arduino as ISP for Attiny84 errors.
I have been able to use my Arduino as a ISP for my Attiny84 for a blinking LED sketch. However, I need Arduino to program my Attiny84 using software written for openenergymonitor. I have followed the steps on this page:http://wiki.openenergymonitor.org/index.php?title=Raspberry_Pi#.28Optional.29_Bootload_the_ATtiny84. The steps basically say to download a tiny folder and put it in the hardware folder to allow certain boards(attiny's) to appear when you select a board. As I stated earlier I have been successful in programming my tiny84 for programs that aren't of my interest. I even have been successful with uploading a bootloader with the errors:"avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny84," which I have read are OK. But, when I try to upload or even compile this sketch I get an error that expands throughout all of the steps I am required to do. Error: c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn84.o: In function __vector_default': (.vectors+0x2): relocation truncated to fit: R_AVR_13_PCREL against symbol __vector_1' defined in .text.__vector_1 section in core.a(WInterrupts.c.o)
c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn84.o: In function __vector_default': (.vectors+0x16): relocation truncated to fit: R_AVR_13_PCREL against symbol __vector_11' defined in .text.__vector_11 section in core.a(wiring.c.o)
c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn84.o:(.init9+0x0): relocation truncated to fit: R_AVR_13_PCREL against symbol main' defined in .text.main section in core.a(main.cpp.o) c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn84.o:(.init9+0x2): relocation truncated to fit: R_AVR_13_PCREL against symbol exit' defined in .fini9 section in c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25\libgcc.a(_exit.o)
SoftwareSerial\SoftwareSerial.cpp.o: In function SoftwareSerial::begin(long)': C:\Users\brand_000\Desktop\Arduino Folder\libraries\SoftwareSerial/SoftwareSerial.cpp:385: relocation truncated to fit: R_AVR_13_PCREL against symbol __mulhi3' defined in .text.libgcc section in c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25\libgcc.a(_mulhi3.o)
C:\Users\brand_000\Desktop\Arduino Folder\libraries\SoftwareSerial/SoftwareSerial.cpp:388: relocation truncated to fit: R_AVR_13_PCREL against symbol __mulhi3' defined in .text.libgcc section in c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25\libgcc.a(_mulhi3.o) SoftwareSerial\SoftwareSerial.cpp.o: In function SoftwareSerial::available()':
C:\Users\brand_000\Desktop\Arduino Folder\libraries\SoftwareSerial/SoftwareSerial.cpp:443: relocation truncated to fit: R_AVR_13_PCREL against symbol __divmodhi4' defined in .text.libgcc section in c:/users/brand_000/desktop/arduino folder/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25\libgcc.a(_divmodhi4.o) Tim_RF12_Tiny_Demo_dB.cpp.o: In function saveConfig':
C:\Users\brand_000\Desktop\Arduino Folder/Tim_RF12_Tiny_Demo_dB.ino:87: relocation truncated to fit: R_AVR_13_PCREL against symbol rf12_config(unsigned char)' defined in .text._Z11rf12_configh section in Jeelib\RF12.cpp.o C:\Users\brand_000\Desktop\Arduino Folder/Tim_RF12_Tiny_Demo_dB.ino:88: relocation truncated to fit: R_AVR_13_PCREL against symbol Print::println(char const*)' defined in .text._ZN5Print7printlnEPKc section in core.a(Print.cpp.o)
Tim_RF12_Tiny_Demo_dB.cpp.o: In function showHelp': C:\Users\brand_000\Desktop\Arduino Folder/Tim_RF12_Tiny_Demo_dB.ino:144: relocation truncated to fit: R_AVR_13_PCREL against symbol Print::print(char const*)' defined in .text._ZN5Print5printEPKc section in core.a(Print.cpp.o)
C:\Users\brand_000\Desktop\Arduino Folder/Tim_RF12_Tiny_Demo_dB.ino:145: additional relocation overflows omitted from the output
Now I done every single step probably 5-6 times at least and even used different versions of Arduino: 1.0.3, 1.0.5, 1.0.6. I have tried every single forum post and was curious if I am just missing something so obvious it's invisible?
Thanks for all help in advance.
Also here is the code:
#include <SoftwareSerial.h>
#define txPin 7 //PA3         AIO1 - > Connect to RX on USB BUB
#define rxPin 8 //PA2 3 //PA7 DIO1 - > Connect to TX on USB BUB
// 19k200
SoftwareSerial mySerial(rxPin, txPin);
               VCC  1|    |14  GND
          (D0) PB0  2|    |13  AREF (D10)
          (D1) PB1  3|    |12  PA1 (D9)
             RESET  4|    |11  PA2 (D8)
INT0  PWM (D2) PB2  5|    |10  PA3 (D7)
      PWM (D3) PA7  6|    |9   PA4 (D6)
      PWM (D4) PA6  7|    |8   PA5 (D5) PWM
#include <JeeLib.h>
#include <util/crc16.h>
#include <util/parity.h>
//#include <avr/pgmspace.h>
#include <avr/eeprom.h>
//#define LED_PIN     0   // activity LED, comment out to disable
#define COLLECT 0x20 // collect mode, i.e. pass incoming without sending acks
static unsigned long now () {
    // FIXME 49-day overflow
    return millis() / 1000;
/*static void activityLed (byte on) {
    pinMode(LED_PIN, OUTPUT);
    digitalWrite(LED_PIN, on);
// RF12 configuration setup code
typedef struct {
    byte nodeId;
    byte group;
//    char msg[30-4];
    word crc;
} RF12Config;
static RF12Config config;
static char cmd;
static byte value, stack[30], top, sendLen, dest ;
static byte testbuf[30], testCounter;
static void saveConfig () {
    // save to EEPROM
    eeprom_write_byte(RF12_EEPROM_ADDR ,config.nodeId);
    eeprom_write_byte(RF12_EEPROM_ADDR +1 ,config.group);
    config.crc = ~0;
    config.crc = _crc16_update(config.crc, config.nodeId);
    config.crc = _crc16_update(config.crc, config.group);
    for (int i=2; i < RF12_EEPROM_SIZE-2; i++) {
        eeprom_write_byte(RF12_EEPROM_ADDR + i, 0);
        config.crc = _crc16_update(config.crc, 0);
    eeprom_write_byte(RF12_EEPROM_ADDR + RF12_EEPROM_SIZE-2 ,config.crc);
    eeprom_write_byte(RF12_EEPROM_ADDR + RF12_EEPROM_SIZE-1 ,config.crc>>8);
    if (!rf12_config())
        mySerial.println("failed");
char helpText1[] PROGMEM =
    "\n"
    "Available commands:" "\n"
    "  <nn> i     - set node ID (standard node ids are 1..26)" "\n"
    "               (or enter an uppercase 'A'..'Z' to set id)" "\n"
    "  <n> b      - set MHz band (4 = 433, 8 = 868, 9 = 915)" "\n"
    "  <nnn> g    - set network group (RFM12 only allows 212, 0 = any)" "\n"
    "  <n> c      - set collect mode (advanced, normally 0)" "\n"
    "  t          - broadcast max-size test packet, with ack" "\n"
    "  ...,<nn> a - send data packet to node <nn>, with ack" "\n"
    "  ...,<nn> s - send data packet to node <nn>, no ack" "\n"
    "  <n> l      - turn activity LED on DIG8 on or off" "\n"
static void showString (PGM_P s) {
    for (;;) {
        char c = pgm_read_byte(s++);
        if (c == 0)
        if (c == '\n')
            mySerial.print('\r');
        mySerial.print(c);
int freeRam () {
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
static void showHelp () {
//    showString(helpText1);
//    mySerial.println("Configuration:");
    config.nodeId = eeprom_read_byte(RF12_EEPROM_ADDR);
    config.group = eeprom_read_byte(RF12_EEPROM_ADDR + 1);
    mySerial.println("EEPROM config: ");
    uint16_t crc = ~0;
    for (uint8_t i = 0; i < RF12_EEPROM_SIZE; ++i){
        crc = _crc16_update(crc, eeprom_read_byte(RF12_EEPROM_ADDR + i));
       mySerial.print(eeprom_read_byte(RF12_EEPROM_ADDR + i),HEX);
    mySerial.println("");
    mySerial.print("crc:");
    mySerial.print(crc);
    mySerial.print(" ");
    byte id = config.nodeId & 0x1F;
 //   mySerial.print('@' + id,DEC);
    mySerial.print("i");
    mySerial.print( id,DEC);
    if (config.nodeId & COLLECT)
         mySerial.print('*');
    mySerial.print(" g");
    mySerial.print(config.group,DEC);
    mySerial.print(" @ ");
    static word bands[4] = { 315, 433, 868, 915 };
    word band = config.nodeId >> 6;
    mySerial.print(bands[band],DEC);
    mySerial.print( "MHz RAM ");
    mySerial.println(freeRam());
    rf12_config();
static void handleInput (char c) {
    if ('0' <= c && c <= '9')
        value = 10 * value + c - '0';
    else if (c == ',') {
        if (top < sizeof stack)
            stack[top++] = value;
        value = 0;
    } else if ('a' <= c && c <='z') {
        mySerial.print("> ");
        mySerial.print((int) value);
        mySerial.println(c);
        switch (c) {
            default:
                showHelp();
            case 'i': // set node id
                config.nodeId = (config.nodeId & 0xE0) + (value & 0x1F);
                saveConfig();
            case 'b': // set band: 4 = 433, 8 = 868, 9 = 915
                value = value == 8 ? RF12_868MHZ :
                        value == 9 ? RF12_915MHZ : RF12_433MHZ;
                config.nodeId = (value << 6) + (config.nodeId & 0x3F);
                saveConfig();
            case 'g': // set network group
                config.group = value;
                saveConfig();
            case 'c': // set collect mode (off = 0, on = 1)
                if (value)
                    config.nodeId |= COLLECT;
                    config.nodeId &= ~COLLECT;
                saveConfig();
            case 't': // broadcast a maximum size test packet, request an ack
                cmd = 'a';
                sendLen = 30;
                dest = value;
                for (byte i = 0; i < 30; ++i)
                    testbuf[i] = i + testCounter;
                mySerial.print("test ");
                mySerial.println((int) testCounter); // first byte in test buffer
                ++testCounter;
            case 'a': // send packet to node ID N, request an ack
            case 's': // send packet to node ID N, no ack
                cmd = c;
                sendLen = top;
                dest = value;
                memcpy(testbuf, stack, top);
 /*          case 'l': // turn activity LED on or off
                activityLed(value);
            case 'q': // turn quiet mode on or off (don't report bad packets)
                quiet = value;
        value = top = 0;
        memset(stack, 0, sizeof stack);
    } else if ('A' <= c && c <= 'Z') {
        config.nodeId = (config.nodeId & 0xE0) + (c & 0x1F);
//        saveConfig();
    } else if (c > ' ')
        showHelp();
//    activityLed(1);
    pinMode(rxPin, INPUT);
    pinMode(txPin, OUTPUT);
    // set the data rate for the NewSoftmymySerial port
    mySerial.begin(19200);
    mySerial.println("\n[Attiny84]");
//    delay(2000);
    if (rf12_config()) {
        config.nodeId = 0x81; // node A1 @ 868 MHz
        config.group = 0xD4;  //212
        rf12_initialize(config.nodeId&0x1F, config.nodeId >> 6 ,config.group);
        saveConfig();
    showHelp();
//    activityLed(0);
    if (mySerial.available())
        handleInput(mySerial.read());
    if (rf12_recvDone() & (rf12_crc == 0) ) {
            mySerial.print("OK");
  //        activityLed(1);
        byte n = rf12_len;
        if (config.group == 0) {
            mySerial.print("G ");
            mySerial.print((int) rf12_grp);
        mySerial.print(' ');
        mySerial.print((int) rf12_hdr);
        for (byte i = 0; i < n; ++i) {
            mySerial.print((int) rf12_data[i]);
        mySerial.print(" (");
//        mySerial.print(rf12_getRSSI(), DEC);
        mySerial.println("dB)");
//        activityLed(0);
        if (rf12_crc == 0) {
//            activityLed(1);
            if (RF12_WANTS_ACK && (config.nodeId & COLLECT) == 0) {
                mySerial.println(" -> ack");
                rf12_sendStart(RF12_ACK_REPLY, 0, 0);
 //           activityLed(0);
    if (cmd && rf12_canSend()) {
//        activityLed(1);
        mySerial.print(" -> ");
        mySerial.print((int) sendLen);
        mySerial.println(" b");
        byte header = cmd == 'a' ? RF12_HDR_ACK : 0;
        if (dest)
            header |= RF12_HDR_DST | dest;
        rf12_sendStart(header, testbuf, sendLen);
        cmd = 0;
 //       activityLed(0);
https://code.google.com/p/arduino-tiny/issues/detail?id=58&can=1&q=R_AVR_13_PCREL
In case you want more details...
Thank you so much.
I found a reply you made: http://forum.arduino.cc/index.php/topic,60649.0.html.
The details of your reply helped me finally upload the file.
Thanks again.
Also I had to use this page: programming problems, could use help. - adafruit industries
to fix an error I received when my usb port messed up after doing all that work. This is just in case anyone has a similar issue.
You are welcome. Glad to know you have it working.
+1 for following instructions
