Hey I'm new at using arduino so hope you all can help me.
I have found this code:
// Wake On Lan ( MagicPacket ) Repeater & Switcher
// Wake On Lan Repeater & Remote Power Button Control
// Support forced release.
// http:yutakalifenet.up.seesaa.net/html/WOLRepSw.html
// Digital 2, output for relay
#include <WString.h>
#include <Ethernet.h>
#include <UdpRaw.h>
byte TargetMac[] = { 0x00,0x00,0x00,0x00,0x00,0x00 }; // set a MAC for Target PC
// ETHERNET CONFIGURATION
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // MAC address
byte ip[] = { 192, 168, 1, 200 }; // Arduino ?IP address
byte gw[] = { 192, 168, 1, 1 }; // Gateway IP address
int localPort = 7; //local port to listen on
// set a target broadcast address
byte targetIp[] = { 192, 168, 1, 255}; // set this value like "x.x.x.255"
int targetPort = 8000; // target port
#define MAX_SIZE 192
// maximum packet size
byte packetBuffer[MAX_SIZE]; // buffer to hold incoming packet
int packetSize; // holds received packet size
byte remoteIp[4]; // holds recvieved packet's originating IP
unsigned int remotePort; // holds received packet's originating port
int i;
int verification;
Ethernet.begin(mac,ip,gw);
UdpRaw.begin(localPort);
pinMode(2, OUTPUT); // initialize D2 pin as an output
// to forward a packet, if incoming packet is available
if(UdpRaw.available()) {
packetSize = UdpRaw.readPacket(packetBuffer,MAX_SIZE,remoteIp,(uint16_t *)&remotePort);
Serial.print("Received packet of size ");
Serial.println(abs(packetSize));
Serial.print("From IP ");
for(i=0; i<3; i++) {
Serial.print(remoteIp[i],DEC);
Serial.print(".");
Serial.print(remoteIp[3],DEC);
Serial.print(" Port ");
Serial.println(remotePort);
if(packetSize < 0) {
// if return value <0 the packet was truncated to fit into our buffer
Serial.print("ERROR: Packet was truncated from ");
Serial.print(packetSize*-1);
Serial.print(" to ");
Serial.print(MAX_SIZE);
Serial.println(" bytes.");
Serial.println("Contents:");
for(i=0; i<min(MAX_SIZE,abs(packetSize)); i++) {
Serial.print(packetBuffer[i],HEX);
Serial.print(" ");
Serial.println("");
for(i=6; i<102; i++) {
int j = abs((102 - i) % 6 - 6);
if ( j == 6 ) j = 0;
if (TargetMac[j] == packetBuffer[i]) verification++;
if (j == 0) {
if(packetBuffer[i] == 0xFF) verification += 2;
// if first byte of Target MAC is 0xFF, relay is ON for 10sec
if(verification>=112){
Serial.println("RELAY ON for 10000ms");
digitalWrite(2, HIGH); // relay is ON
delay(10000); // wait for 10sec
digitalWrite(2, LOW);
}else{
// if receive MagicPacket to Target PC, then relay is ON for 1sec
if(verification>=96){
Serial.println("RELAY ON for 1000ms");
delay(1000); // wait for 1sec
// send a magic packet
UdpRaw.sendPacket(packetBuffer,packetSize,targetIp,targetPort);
Serial.println("Start port forwarding to broadcast address:");
Serial.print(targetIp[i],DEC);
Serial.print(".");
Serial.print(targetIp[3],DEC);
Serial.println("");
Serial.println("Done!");
verification = 0;
// wait a bit
delay(10);
But it fails when i want to send it to the arduino.
I also want to modify it a little. I would like it to listenfor the magic packet, when it recieves the on for making pin 2 go high it has to check the state of Pin2 if it is LOW the go HIGH, if it is HIGH then go low.
Hope that you can help me =)
