Hello,
I am trying to get Eclipse working with my Arduino DUE. i am using the eclipse downloaded from here which includes the Arduino Plugin. i have Arduino IDE v1.5.7 installed on the same machine.
i am trying to run this simple sketch:
//The setup function is called once at startup of the sketch
// Add your initialization code here
// The loop function is called in an endless loop
//Add your repeated code here
static int = 0;
Serial.print("Board 1: ");
Serial.println(++i);
delay(100);
if i click verify i get the following output:
16:02:17 **** Incremental Build of configuration Release for project ConnectionManager ****
make all
Cannot run program "make": Launching failed
Error: Program "make" not found in PATH
PATH=[C:/Program Files (x86)/Arduino/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/;C:/Program Files (x86)/Arduino/hardware/tools/g++_arm_none_eabi/arm-none-eabi/bin;C:/Program Files (x86)/Arduino/hardware/tools/avr/utils/bin;C:/Program Files (x86)/Java/jre7/bin/client;C:/Program Files (x86)/Java/jre7/bin;C:/Program Files (x86)/Java/jre7/lib/i386;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Perforce;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft SDKs\TypeScript\1.0\;C:\Python27;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\EclipseArduino]
16:02:17 Build Finished (took 35ms)
when clicking upload i get the following output and i see the led flashing on the due board.
Starting upload
using arduino loader
Launching C:/Program Files (x86)/Arduino/hardware/tools/bossac.exe --port=COM4 -U false -e -w -v -b C:\Users\home\Documents\Arduino-Eclipse\ConnectionManager/Release/ConnectionManager.bin -R
Output:
Erase flash
No such file or directory
C:/Program Files (x86)/Arduino/hardware/tools/bossac.exe finished
upload done
when i connect to the serial monitor, nothing happens. although if i do send something to the board via the monitor i do see the led flash on the board.
also, eclipse shows errors throughout the code.
has anyone gotten the eclipse ide working with the due board? does anyone have any suggestions?
