Using Arduino IoT Cloud to control PCF8574 as output
I'm currently using an Arduino Nano 33 Iot, however, due to my project being large scale I would require more GPIO pins for output control of my LED lights. I have decided to use the PCF8574 expansion module and it will be connected to a npn transistor to control my relay, however, when I turn on/off my LED light (Arduino Things), the PCF8574 doesn't output the voltage and current to turn on my relay.
My code below:
  bool lED;
  bool lED2;
  bool lED3;
  bool lED4;
  bool lED5;
#include "thingProperties.h"
#include <Wire.h>
int PCF_Output = 0x20;
byte PCF8574OUTPUT = B00000000; //sets a variable to be used for logic operator
  // Initialize serial and wait for port to open:
  Wire.begin();
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(A0, OUTPUT);
  pinMode(A1, OUTPUT);
  Wire.beginTransmission(PCF_Output);
  Wire.write(0x00);
  Wire.endTransmission();
  delay(1500); // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
// int voltage_2 = analogRead(A1);
// core_2_Value = voltage_2 * (5.0/1024.0);
 // delay(10);
void onLEDChange()  {
  Serial.println(lED);
  if (lED) {
    digitalWrite(A0, HIGH);
    Wire.write(0x01);
  else {
    digitalWrite(A0, LOW);
    Wire.write(0x00);
void onLED2Change()  {
  if (lED2){
    digitalWrite(6,HIGH);
  }else {
    digitalWrite(6,LOW);
The onLEDChange() is linked to Core 1 LED variable in Things, by toggling the LED I would like my PCF8574 to turn either on and off when the LED is true and false respectively.
Hi @ntu-spgroup_fyp. Have you tried running a simple sketch that only controls the PCF8574 directly, without any Arduino IoT Cloud code at all in the sketch?
If so, did it work as expected?
If not, I recommend you try that first before introducing the significant additional complexity of Arduino IoT Cloud into the system.
Hi @ptillisch , thanks for the advice! I went to create a simple LED light up between the P0 and P1 of from the PCF8574 without any controls, I have realised the code of my PCF8574 doesn't run within the void loop (). I'm not sure whether if I'm doing anything wrong?
#include "Arduino.h"
#include <Wire.h>
  Wire.begin();
  Wire.beginTransmission(0x20);
  Wire.write(0xFF);
  initProperties();
  Wire.write(0xFE);
  Wire.write(0xFD);
I did some testing and found that the LED lights up only when the PCF8574 is set low (eg 0). So i initialised it to high (0xFF) to off it and to only turn P0 (0xFE) on and P1 (0xFD) on within the loop(). However, it is not working as i intended it to.
