Hi everyone,
This is my first post and I have to admit that I'm quite new to Arduino so please forgive any possible newbie mistake.
I have an Arduino Mega 2560, a uStepper S Stepper Motor Driver and a Nema 23 Stepper Motor.
I managed to control the stepper motor using the uStepper S driver. The board used for this case was uStepper S.
So far so good.
Now I'd like to control the uStepper S driver using the Arduino Mega 2560. My idea is to use SDA - SCL pins for communication (please feel free to propose any better way). I connect the SDA and SCL pins of the Arduino Mega to the SDA and SCL pins of the uStepper. The two devices share a common Ground connection while they have different power supply: uStepper S has its own power supply and the Arduino receives power via the USB connection.
The connections are shown below:
The code I'm using is the following:
#include <uStepperS.h>
#define MAXACCELERATION 70 //Max acceleration = 70 Steps/s^2
#define MAXVELOCITY 70 //Max velocity = 70 steps/s
uStepperS stepper(MAXACCELERATION, MAXVELOCITY);
void loop(){
Serial.println("getMotorState: ");
Serial.println(stepper.getMotorState());
When I try to compile the code I get the following error:
C:\Users\u0161078\Documents\Arduino\libraries\uStepper_S\src/uStepperS.h:142:3: error: #error !!This library only supports the uStepper S board!!
#error !!This library only supports the uStepper S board!!*
C:\Users\u0161078\Documents\Arduino\libraries\uStepper_S\src/uStepperS.h:146:3: error: #error !!This library only supports the ATmega328PB MCU!!
#error !!This library only supports the ATmega328PB MCU!!*
I looked into uStepper.h file and I found that the following checks produce the error:
#ifndef ARDUINO_AVR_USTEPPER_S
#endif
#ifndef __AVR_ATmega328PB__
#endif
Any ideas on how to resolve this error with a final aim to control the uStepper S with my Arduino Mega 2560?
Thanks in advance,
Antonis
