Using Arduino Mega as ISP: Yikes! Invalid device signature.
Hello,
I am trying (for the first time) to burn the Arduino bootloader on a fresh ATMEGA328PU. I am using an Arduino Mega to do so following this tutorial. Using IDE 1.8.2.
Attached is a picture of my setup.
Here are the steps I followed:
1 - Uploaded ArduinoISP onto the Mega
2 - Hooked up the target Arduino (Uno) for bootloading
3 - Installed a 0.1uF cap between RESET/5V on the Mega
4 - Tools > Board > Uno
5 - Programmer > Arduino as ISP
6 - Burn Bootloader
I am getting the following error
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM22
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.03s
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Seems like my wiring is incorrect but I looked several times, switched out wires and no luck.
Is there something I am missing?
Reset lead from pin 10 of the Mega to reset of the Uno.
I switched over using an old Diecimila with an Uno (rather than using the Mega). After changing the signature in the acrdude.conf file. I was able to burn the bootloader on the ATMEGA328.
