Hi all,
As the title of my post suggests I have connected 6 flexible resistive pressure sensors (in a voltage divider configuration 10kOhm resistor) to my arduino mega analog channels A0-A5. My goal is to have a calibration routine in the setup where readings are taken with no load on the sensors and with a known load (ex: 0.5kg) applied and then relating adc minimum and maximum values to no load and max load respectively.
I am trying to do it by declaring a 3row, 6 column array that takes in sensor numbers, their min adc values, their max adc values in row1, row2, row3, respectively. Then calling a calibrate function that counts through the array and populates min adc and max adc values so that I can use them later in the code to map to min and max load for each sensor. However, that's not happening; my calibrate function is not populating the allocated array elements with those values. What am I doing wrong?
//set pressure sensor in voltage divider config; Vcc-Psensor-Vout_to_arduino-10k res-ground
//relate Vout_to_arduino to mass on pressure sensor and display the mass on LCD
//problem: resistive pressure sensors have an unpredictable ohmic resistance response (and by extension adc value range)
//to make consistent readings of mass from pressure sensors need to get adc min and max values of each (which differ from one another)
//and map them to 0 g and max grams (eg 1kg)
//write calibration loop that looks at individual sensors no load adc value and known
//load adc value, then map those values to 0 grams and max grams for each
#include<Math.h>
#include<LiquidCrystal.h>
const int row_num = 3;
const int column_num = 6;
int p_sensor1 = A0;
int p_sensor2 = A1;
int p_sensor3 = A2;
int p_sensor4 = A3;
int p_sensor5 = A4;
int p_sensor6 = A5;
int min_adc1 = 0;
int min_adc2 = 0;
int min_adc3 = 0;
int min_adc4 = 0;
int min_adc5 = 0;
int min_adc6 = 0;
int max_adc1 = 0;
int max_adc2 = 0;
int max_adc3 = 0;
int max_adc4 = 0;
int max_adc5 = 0;
int max_adc6 = 0;
// declare an array of 3 rows and 6 columns
//3 row, 6 column array that stores indexed numbers of sensors on first, min_adc_readings on second, and max_adc_readings on third rows
int p_sensor[row_num][column_num] = {{p_sensor1, p_sensor2, p_sensor3, p_sensor4, p_sensor5, p_sensor6},
{min_adc1, min_adc2, min_adc3, min_adc4, min_adc5, min_adc6},
{max_adc1, max_adc2, max_adc3, max_adc4, max_adc5, max_adc6}
}; // can do 2D array int p_sensor[3] [6]
void setup(){
pinMode(p_sensor1, INPUT);
pinMode(p_sensor2, INPUT);
pinMode(p_sensor3, INPUT);
pinMode(p_sensor4, INPUT);
pinMode(p_sensor5, INPUT);
pinMode(p_sensor6, INPUT);
calibrate_sensors();
//delay(1000);
//prompt user to remove any load on sensors if any and press button
//initiate calibration for no load
//prompt user to apply known load to each sensor and press button
//initiate calibration for known load
Serial.println("values in array: first row");
Serial.println(p_sensor[0][0]);
Serial.println(p_sensor[0][1]);
Serial.println(p_sensor[0][2]);
Serial.println(p_sensor[0][3]);
Serial.println(p_sensor[0][4]);
Serial.println(p_sensor[0][5]);
Serial.println("values in array: second row");
Serial.println(p_sensor[1][0]);
Serial.println(p_sensor[1][1]);
Serial.println(p_sensor[1][2]);
Serial.println(p_sensor[1][3]);
Serial.println(p_sensor[1][4]);
Serial.println(p_sensor[1][5]);
Serial.println("values in array: third row");
Serial.println(p_sensor[2][0]);
Serial.println(p_sensor[2][1]);
Serial.println(p_sensor[2][2]);
Serial.println(p_sensor[2][3]);
Serial.println(p_sensor[2][4]);
Serial.println(p_sensor[2][5]);
void loop(){
//Serial.println(p_sensor[0][0]);
void calibrate_sensors() {
for (int i = 0; i <= 5; i++) {
Serial.println("I'm in for loop");
Serial.println("i is: ");
Serial.println(i);
Serial.println("Value at index 0, i of array is: ");
Serial.println(analogRead(p_sensor[0][i]));
if (analogRead(p_sensor[0][i]) <= 0) {
Serial.println("I'm in less than zero if...");
p_sensor[1][i] == analogRead(p_sensor[0][i]);
Serial.println(p_sensor[1][i]);
if (analogRead(p_sensor[0][i]) > 0) {
Serial.println("I'm in more than zero if..");
p_sensor[2][i] == analogRead(p_sensor[0][i]);
My serial monitor output
I'm in for loop
i is:
0
0
0
I'm in for loop
i is:
1
141
I'm in for loop
i is:
2
220
I'm in for loop
i is:
3
262
I'm in for loop
i is:
4
291
I'm in for loop
i is:
5
303
54
55
56
57
58
59
0
0
0
0
0
0
0
0
0
0
0
0
![pressure sensor voltage divider arduino|666x362](upload://1NMJclmGUh2Czzmu13uVg8O4MUm.png)
