Hello all, I am a beginner with controls and arduino and I was hoping for guidance.
General project: Creating a test bench that operates by running a linear actuator that pushes onto a load cell. I desire to be able to command approximately how much force to operate onto the load cell. The end goal is to be able to command for example 'Apply 20N of force on the load cell'.
Components:
Actuator: P16 50 256 12 P
Load cell (generic brand, not point of focus for this question)
Arduino Uno to read load cell
Arduino mega with motor shield to operate the actuator maybe?
Problem:
This actuator is designed to be used with a control board that I have purchased, however the sensitivity of the control isn't as precise as I need it to be. For example I tried PWM control, and USB control, and with both methods the actuator provided too much force per increment.
As a result, I am trying to just use the actuator like a DC motor. The thing is, I need to limit the current at 0.05 amps for it to operate at the force/speed I need it to. As a result, I need to come up with a solution to be able to deliver a maximum of 0.05A of current.
If there is anyone who has an idea of how I can begin to use a motor shield with this actuator to current control it, I would appreciate it.
The idea is eventually if I desire 20N of force, I will apply power to the actuator with the current being controlled, and using a closed loop with the feedback from load cell descend until 20N is applied, then completely cut power and leave the actuator in its position until further commands.
