Greetings Everyone,
I’m posting this question because I haven’t been able to find a good explanation of how to use the current sense pins (A0,A1) on the Arduino’s motor shield. I am a beginner in using the Arduino hardware and in general with development boards. I have a Mega 2560 along with the motor shield and am using them to drive a single 9V dc motor, with 8 1.2V Ni-MH batteries as the source. My sketch drives the motor first in one direction, speeding it up while taking readings from the current sense pin, then slowing it down, then repeating in the other direction. Here is the portion for going in one direction:
int dirA = 12;
int speedA = 3;
int brakePin = 9;
int currentA = 0;
int val = 0;
Serial.begin(9600); // open serial port
pinMode (dirA, OUTPUT);
pinMode (speedA, OUTPUT);
pinMode (brakePin, OUTPUT);
// move the motor A to one direction increasing speed
digitalWrite (dirA, HIGH);
for (int j = 0; j < 255; j += 10)
analogWrite (speedA, j);
val = analogRead(currentA); // read the current sense pin
Serial.println(val); // send the value to the serial port
delay (250);
delay(1000); // keep the motor rolling for one second
// move the motor A to one direction decreasing speed
for (int j = 255; j >= 50; j -= 10)
delay (250);
This is what I’m reading from the serial monitor for current:
100ms delay 250ms delay 500ms delay
15 15 15
15 15 15
15 278 508
227 298 15
475 48 15
15 15 342
15 255 15
79 186 15
279 181 190
383 15 426
15 307 15
16 228 63
262 179 345
309 175 215
297 186 15
15 191 339
171 201 324
244 119 15
238 15 233
159 261 354
231 239 172
153 178 148
257 15 229
53 335 89
232 303 448
253 228 236
204 15 15
15 15 302
33 419 322
210 55 16
385 15 34
15 15 316
15 433 429
I tried it at three different delay intervals since the 100ms delay seemed erratic. Is the current sense pin calibrated to output actual current readings rather than a number between 0 and 1023? The no-load max current for my little hobby motor is 380mA so these numbers seem reasonable. What I notice for observing the current readings over a longer period than shown here is that at low speeds, corresponding to small PWM value, there tends to be a single large current reading surrounded by 15’s—essentially 0 current—readings. As the speed picks up there are more frequent ‘injections’ of smaller current values corresponding to a higher average current to drive the motor faster. Could someone tell me if I’m interpreting this right?
For a project I’m working on, I would like to drive two 12V linear actuators or a linear actuator and slewing drive to operate a solar tracker. I would very much like to make use of this current sense reading to monitor the power consumption of the motors throughout the day but would like it to be more accurate than it seems to be in my current experiments. Could anyone suggest how I might do this?
Thanks in advance for your help.
TonyL
