Hi. Looking to swap out the capstan motor on an old reel to reel.
I have an old reel to reel recorder that I never use.
I want to somehow control the speed of the capstan motor. I have an arduino nano that I thought I could use as a controller.
It has an AC motor inside, which seems to be difficult to hack to do varispeed/speed control.
That’s why I want to swap it out with a newer dc motor.
My plan is to ditch the reel mechanics and only rely on capstan motor to push the tape. (I will make a "cage" for the tape tape loop, so won't need the 2 reels. Just the capstan).
I can find many brushless dc motors, but I want one that has high enough torque at low rpm. Most dc motors have insane rpm that is not needed at all, and I want to make sure that hey perform well at low rpm.
I found this on the internet:
"On the capstan a roller of varying diameter from model to model is mounted - typically around 1 - 2 inches, which means somewhere between 4-5 inches of tape is transported per round (1.5 * 3.14159 = 4.7). If the speed is e.g. 30 inches per second, then that gives 30 / 4.7 * 60 ~= 383 RPM for the capstan. The reels are harder because many different reel types exist, with varying starting inner diameter."
If I then rewrite that to 15 ips, as medium speed?
If the speed is e.g. 15 inches per second, then that gives 15 / 4.7 * 50 (im in Denmark and we use 50hz) ~= 159 RPM
So that means that I have to find a DC brushless motor that can give me 159 rpm (or in that ball park).
I can then add varispeed to that pretty easily it seems (maybe with pwm or other techniques).
I am guessing
I'm thinking that the drone industry has made huge strides in the DC motor area, but they are all very fast. I need slow and reliable.
It seems that KV=rpm. So I should get a DC brushless 159KV motor.
Or should I not worry at all about torgue? It only needs to keep the tape rolling ![]()
Any hints on where go looking? Any hints for making a good controller?
This is the original motor in the machine. But I only need a new motor for driving the capstan. Not the actual reels.
Thanks
