Using arduino to control opening and closing of valve input from optical sensor
hello, i am doing my final year engineering project in which i control a exhaust valve in a two stroke engine (i am designing the valve) which is controlled by a arduino borad which receives input from optical crankshaft sensor.
I'm thinking of using the arduino uno r3 for this is it suitable for this type of project or should i go for someother boards?
your sugestions are welcome for any other ideas.
PS:
i am in starting stage of the project and havent done indepth study of sensors and valve.
if possible link some of the sensors which i can use.
Yes, UNO R3 is suitable. Or a "Pro Mini" with a USB to TTL adapter for programming, which can be disconnected in actual use when not needed for programming & monitoring.
Example using opto-reflective device. Also, try googling for opto-interrupter device. Either will work for your project. - Scotty
thank you for the reply scotty & paul.
and any thoughts on using solenoid valve to control exhaust gasses and if possible can you link me to the code source.
:slight_smile:
pranav93:
Ah well, that's the engineering part which is rightly your domain.
As to the code, you have to figure out exactly what sequence of events it must perform and - having played around with as many of the examples available to do each little bit that may be relevant including simply flashing a light at a certain rate with a certain "on-off" duty cycle and a variable speed to mimic your valve control - come up with some code to perform the task and post it here for critique.
I do not know of a "code source" for such a task - you may be able to find one or you may not by searching (that's what university projects are about); most likely you will have to write that "code source".
thanks reply
i'll get started as sonn as i get the arduino. i'll probably get it by tomo. 8)
