using arduino to recognise gestures
To me, this project isn't about gestures.... to me a gesture implies movement and perhaps that's where the accelerometer would come in. This project is more about poses,
Exactly. ]:slight_smile:
Thinking the project was actually about gestures is what prompted me to write the earlier replies. A crap question always generates a crap reply.
It seem that the project as now framed is much more doable.
You haven't mentioned what the purpose of the accelerometer is?
I suspect just to show if the finger is pointing up or down.
That is possible but requires a bit of skill mounting small surface mounting packages on fabric. Then trying to address all five accelerometer without a ton of wiring is tricky. Most accelerometers are I2C devices but with not that many addresses. The analogue output accelerometers have a small output prone to noise pickup.
Or at least a Grumpy one.....
JimboZA:
Yes indeed. :wink:
looking at the diagrams posted, you could start off a crude prototype with a glove with 5 microswitches at the base of each digit ( digit bent or straight ) and a contact at the end of the thumb and the tips of the fingers for 6, 7, 8 ,and 9 .
You could use 10 " if" statements ( I am talking crude here ) the contacts would override the microswitch combinations ?.
Lots of work to do, but it could be a start.
