Using Arduino UNO with DWM1000
Greetings Guys,
Just a while ago, I’ve seen a page called “Wayne’s Tinkering Page” (Link: UWB Ranging with the DecaWave DWM1000 - Part II - Wayne's Tinkering Page).
The idea was to use his PCB design that can be ordered via “OSH Park” and use the “arduino-dw1000” library (Link: GitHub - thotro/arduino-dw1000: A library that offers functionality to use Decawave's DW1000 chips/modules with Arduino.) to get the “DWM1000” running and do some “Indoor Locating System” with it.
The problem is, after soldering all the components and verifying that everything is fine, I connected the “Arduino UNO” and uploaded the “Basic Connectivity Test” example without changing any parameter. The figure below shows the output of the serial monitor (or see the attachments):
!(http://)
Note that every 10 seconds the uController tries to re configure the “DWM1000” and outputs the results to the serial monitor.
Could anyone please help me with this?
Does the output of the serial monitor shows that the module is working properly? :confused:
The linked site uses an Arduino Pro Mini and not an Arduino UNO. Post a wiring diagram of how you connected your UNO to the custom PCB. The output shows that you don't have a working SPI connection to the module so I guess it's a hardware problem.
Hi Pylon,
Thank you very much for your response :slight_smile: .
I connected the SPI pins on Wayne Holder (10, 11, 12, 13) to the SPI pins in UNO (10, 11, 12, 13). Pin 2 and 9 on Wayne Holder were also connected to pin 2 and 9 in the UNO shield as well. The +5v supply of Wayne holder was also taken from the shield - as shown in the figure below.
As far as I know -please correct me if I'm mistaken-, both Pro Mini and Uno uses the same Atmega325p uController. So, I though I could use the same pin numbers and example code.
Thank you in advance ;D
That seems to be correctly wired. You should check if the level converter on-board the Wayne Holder works correctly. Power the Wayne holder using the USB connector on the board and don't connect the UNO. Then put 5V to pin 10, 11 and 13. Check if the output has 3V3 on the DWM1000, SS (10) goes to pin 1, MOSI (11) to pin 2 and SCKL (13) to pin 4, counted from the USB connector to the antenna and on the side of the R2.
The opposite direction (MISO) isn't that easy to check. You might give 5V to SS and put 3.3V (from the side pins on the Wayne board) to pin 3 of the DWM1000 and check if you get 5V on MISO (12).
Thanks again for your response pylon :grinning:
I believe I checked pin 10, 11 and 13 and the output of the level converter was 3.3v. But unfortunately I didn't check (MISO).
Once I go back to the lab on Sunday I will double check all SPI pins again and (MISO) the way you suggested.
I really appreciate your responses, many thanks :wink:
Greetings Guys,
I measured the voltages at DecaWave board SPI pins (SS, MOSI, CLK) relative to the common ground while supplying the board using the USB and without connecting the UNO board.
What I saw on the oscilloscope screen is a bit strange:
  • I always measure 3.3 volts at the Decawave's SPI pins (SS, MOSI, CLK) even when no 5v is connected to the input of the LLC.
  • For one of another board, I measure a square wave of 10Hz and 3.3v as well without connecting anything to the input of the LLC.
Does this means that my Decawaves and the boards are burned :frowning: .
Please advice, Many thanks ....
Please help ??!!!
I came across the fact that the main difference between UNO and Pro Mini is the operating clock. Could that be the reason why there is something wrong with the SPI communication ?
The 5V Mini runs on 16MHz too. The 3V3 Mini runs on 8MHz. I expected you to have the 5V version.
That's correct, connect the input to GND and the output should go to GND too. That's the way the internal level converter works (a simple MOSFET).
For what kind of board are you measuring on what pins?
Thank you very much for your time pylon, I really appreciate your help.
I tested the (SS, MOSI and CLK) pins the way you told me by connecting the LLC input to GND and measure the voltage at the corresponding pin on the DWM1000 side. And what happens is as you said - the output goes to GND as well.
I tested the MISO pin the same way you suggested, and I also got 5v at the output of the LLC :slight_smile: .
About the square wave that I get on the second board I soldered - which is another Wayne board, I get something like a square wave at SS and MOSI pins when the input of the LLC is floating - not connected to anything. But when I connect the LLC input to GND the output goes to GND as well.
Thank you very much for your help again :grinning:
SS and MOSI are on the inputs of the corresponding LLCs. I don't understand what exactly you measured.
Hello Pylon,
Sorry for the late response.
pylon:
I Actually scraped this one because the other PCB I soldered started working properly. I did nothing and it just started working properly after I did the test you told me about. I know its strange but this what happen.
I soldered another two PCBs, exactly the same way I did for the one that is working fine. The problem with these ones is that they sometimes work and sometimes not.
When I connect them and upload the connectivity test example, I get the correct addresses and everything. But after few reads - which happen every 10 seconds - I start getting wrong info - which implies that the SPI communication went wrong.
I tested the outputs of the LLC and everything seems to work fine.
Is there a chance that I damaged the DWM1000 module while soldering it and that's why it behaves funny?
Is there a chance that I damaged the DWM1000 module while soldering it and that’s why it behaves funny?
It’s possbile but I don’t believe so. This sounds more like a bad soldering point. Use a magnifying glass to check every soldering point and resolder it if it doesn’t shine.
Hi Guys,
Thank you Pylon for your replies,
I inspected the soldering I did as well as a continuity test and everything seemed to be fine.
I soldered a 1.2K ohm pull-up resistors on the SPI bus and magically it worked ;D ;D ;D ;D
I suspected the reason to be as the following:
  • when using the pro mini, the SPI bus wires are short enough and doesn't catch enough noise to ruin the communication.
  • I used an arduino UNO and a longer wares that acted as antenna. This might result in catching enough noise to ruin the communication sometimes.
Please correct me if I was wrong. I will keep this post updated to spread the knowledge.
Many thanks guys :smiley:
An SPI bus shouldn't need pull-ups, you ruin the bus (you cannot connect another device) with the pull-ups. How long are the wires you use the for SPI bus? 20cm shouldn't be a problem.
Hi Pylon,
Sorry for the late reply :smiley: ,
The wires I used for connecting the arduino to Waynes board are the normal 20cm jumper wires.
I tried using pull-up resistors with two other boards and they started working fine.
Could it be that the ground connection is bad or something ???
It is really a curious case :smiling_imp:
Hi Guys,
I just wanted to update those who are following this thread.
I just received the Arduino Pro mini which is meant to be used with Wayne's PCB and guess what ?
It eliminated the need for Pull-Up or down resistors - because there are ones already built-in in the DWM1000 module as per the datasheet.
So, I successfully tested the Anchor/Tag ranging example and they just work fine.
Now the next step is to calibrate the thing because it gives and initial error of about 0.5 meters when it should be 0 or so.
Thanks !
Im using the pro mini as well... Im just learning this chip, can you point me in the direction of where I can find a pinout diagram?
Thanks
If you are using Wayne's breakout board to connect both the pro-mini and DWM1000, there is no need to do any additional connections.
BR,
Qassim
