Using Arduino with Processing 3 and a Joystick to control Servos and LEDS !
Hello, Arduino community,
I’m new to coding in general so please bear with me.
I am trying to control 2 servos and a bunch of LEDs attached to an Arduino Nano clone using Logitech Attack3 Joystick and Processing with the GameControlPlus library.
I figured out how to control the Servos as shown in the code below, but I have no idea how can I make pressing a button on the joystick control an LED, I need a sample code to do that so I can build on it.
Question 2 :
When using Processing with Arduino, do I create the entire code in Processing? I mean what will be the Arduino and Arduino IDE job afterward other than uploading the Firmatta code to it and attaching the devices to be controlled to it?
I already uploaded the Firmata Sketch to my Arduino Nano,
The Processing code:
import processing.serial.*;
import net.java.games.input.*;
import org.gamecontrolplus.*;
import org.gamecontrolplus.gui.*;
import cc.arduino.*;
import org.firmata.*;
ControlDevice cont;
ControlIO control;
Arduino arduino;
float joystickX;
float joystickY;
boolean but1;
int servoXPin=3;  // Where servoX is connected to arduino
int servoYPin=5;  // Where servoY is connected to arduino
  size(360, 200);
  control = ControlIO.getInstance(this);
  cont = control.getMatchedDevice("attack3");
  if (cont == null) {
    println("Controller not connected! Please check it out.");
    System.exit(-1);
  } //End of "if" code
  println(Arduino.list());  //Reads the connected USB devices
  arduino = new Arduino(this, Arduino.list()[2], 57600);
  arduino.pinMode(servoXPin, Arduino.SERVO);
  arduino.pinMode(servoYPin, Arduino.SERVO);
  arduino.pinMode(13, Arduino.OUTPUT);
} //End of void setup loop
public void getUserInput() {
  joystickX = map(cont.getSlider("servoX").getValue(), -1, 1, 0, 180);
  joystickY = map(cont.getSlider("servoY").getValue(), -1, 1, 0, 180);
  but1 = cont.getButton("bn1").pressed();  // NOT SURE IF THIS PART IS CORRECT!!!!
  /*joystick = map(cont.getSlider("bn2").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn3").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn4").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn5").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn6").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn7").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn8").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn9").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn10").getValue(), 0, 1, 0, 1);
   joystick = map(cont.getSlider("bn11").getValue(), 0, 1, 0, 1);
  print(but1);
  print (", ");
  print(joystickX);
  print (", ");
  println (joystickY);
  delay (100);
} // End of public void loop
void draw() {
  getUserInput();
  background(joystickX, 100, 255);
  background(joystickY, 50, 180);
  arduino.servoWrite(servoXPin, (int)joystickX);
  arduino.servoWrite(servoYPin, (int)joystickY);
  if (but1 == true) {
    arduino.digitalWrite(13, 1); // NOT SURE OF THIS WOULD WORK TO TURN ON ARDUINO LED 13
No, you need to develop the Processing code using the Processing IDE, and the Arduino code using the Arduino IDE.
The firmata code knows how to deal with specific data coming in the serial port. The IDE won't be doing anything, not even acting as a cheerleader.
The documentation for the ControlDevice library should explain how to get the state of a switch on the device you have connected. The documentation for the Arduino class should tell you which method to call to turn a digital pin on or off.
