Hello,
I wanted to use the WizFy shield for Arduino in order to implement wireless communication in a project that I am working on. I was trying to compile an exmaple program to see how it works, however, the IDE seems to be stuck at compiling the code:
WizFiShield Basic Server Test Example
This sketch makes the server socket and accpet TCP connection from the client
Circuit:
WizFiShield connected to Arduino via SPI
RST: pin 2 // Output
DRDY: pin 3 // Input
CSB: pin 4 // output
MOSI: pin 11 // output
MISO: pin 12 // input
SCK: pin 13 // out
Created 27 Sep. 2012
by James YS Kim (jameskim@wiznet.co.kr, javakys@gmail.com)
Modified 27 May. 2013
by Jinbuhm Kim (jbkim@wiznet.co.kr, jinbuhm.kim@gmail.com)
// WizFi210 communicates using SPI, so include the SPI library:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <SPI.h>
#include <WizFi2x0.h>
#include <WizFiClient.h>
#include <WizFiServer.h>
#include <TimerOne.h>
#define SSID "borsuk" // SSID of your AP
#define Key "1234678901234567890123456" // Key or Passphrase
// Wi-Fi security option (NO_SECURITY, WEP_SECURITY, WPA_SECURITY, WPA2PSK_SECURITY)
#define Security WPA_SECURITY
unsigned int SrcPort = 50000; // listening port number
WizFi2x0Class myWizFi;
WizFiClient myClient[4];//(SIP, ServerPort);
WizFiServer myServer(SrcPort);
TimeoutClass ConnectInterval;
boolean Wifi_setup = false;
// 1msec Timer
void Timer1_ISR()
myWizFi.ReplyCheckTimer.CheckIsTimeout();
byte retval, i;
Serial.println("\r\nSerial Init");
for(i=0; i<4; i++)
myClient[i] = WizFiClient();
myWizFi.begin();
ConnectInterval.init();
// Timer1 Initialize
Timer1.initialize(1000); // 1msec
Timer1.attachInterrupt(Timer1_ISR);
myWizFi.SendSync();
myWizFi.ReplyCheckTimer.TimerStart(3000);
Serial.println("Send Sync data");
while(1)
if(myWizFi.CheckSyncReply())
myWizFi.ReplyCheckTimer.TimerStop();
Serial.println("Rcvd Sync data");
if(myWizFi.ReplyCheckTimer.GetIsTimeout())
Serial.println("Rcving Sync Timeout!!");
// Nothing to do forever;
for(;;)
// AP association
while(1)
byte tmpstr[32];
retval = myWizFi.associate(SSID, Key, Security, true);
if(retval == 1){
myWizFi.GetSrcIPAddr(tmpstr);
Serial.println("AP association Success");
Serial.print("MY IPAddress: ");
Serial.println((char *)tmpstr);
Wifi_setup = true;
}else{
Serial.println("AP association Failed");
if(myServer.begin())
Serial.println("Server Listen OK");
Serial.println("Server Listen Failed");
uint8_t i;
byte rcvdBuf[129];
memset(rcvdBuf, 0, 129);
if(Wifi_setup)
myWizFi.RcvPacket();
for(i=0; i<4; i++)
if(myClient[i].available()){
if(myClient[i].read(rcvdBuf))
Serial.print("CID[");
Serial.print((char)myClient[i].GetCID());
Serial.print("]");
Serial.println((char *)rcvdBuf);
myClient[i].write(rcvdBuf);
The progress is stuck here:
Build options changed, rebuilding all
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library WizFiShield in folder: C:\Users\Damian\Documents\Arduino\libraries\WizFiShield (legacy)
Using library TimerOne in folder: C:\Users\Damian\Documents\Arduino\libraries\TimerOne (legacy)
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield -IC:\Users\Damian\Documents\Arduino\libraries\TimerOne C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\WizFiBasicServerTest.cpp -o C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\WizFiBasicServerTest.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield -IC:\Users\Damian\Documents\Arduino\libraries\TimerOne -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\utility C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\SPI.cpp -o C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\SPI\SPI.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield -IC:\Users\Damian\Documents\Arduino\libraries\TimerOne -IC:\Users\Damian\Documents\Arduino\libraries\WizFiShield\utility C:\Users\Damian\Documents\Arduino\libraries\WizFiShield\HTMLPages.cpp -o C:\Users\Damian\AppData\Local\Temp\build1556776878667064971.tmp\WizFiShield\HTMLPages.cpp.o
I am working in Win8, but never had a problem until now. I have a feeling that this code is simply outdated, but then so would the literature about it.
EDIT: Works for IDE v1.5.5 but not for 1.6.4. In 1.6.5 it gives me error messages about the HTMLpages.cpp library.
Thanks for your help.
