Using Arduino Zero SERCOM3 port for I2C
Hello,
I’m working on a project that uses the Arduino Genuino Zero board to communicate with a sensor over I2C. I’m trying to use the SERCOM3 (pads 0 and 1) to be SDA and SCL respectively as described in the following tutorial https://www.arduino.cc/en/Tutorial/SamdSercom. The SDA pin is on Digital 0 and SCL is on Digital 1 (referring to the Genuino connector Pins).
The code compiles with no errors, but there is nothing coming back to the serial monitor when uploaded to the board. I did remove the interrupt handler mentioned in the tutorial as it was causing an error of multiple definitions.
The sensor/arduino work perfectly well when using the pre-defined SDA/SCL pins and the standard Wire library, but I really need to want get these other pins set up to read data.
Please note, there are pull-up resistors on the sensor board so I believe this is not the issue.
Any help would be much appreciated - please see attached sketch, source and header files.
Thanks,
Tom
tcs34725.ino (3.25 KB)
Adafruit_TCS34725.cpp (11.2 KB)
Adafruit_TCS34725.h (8.3 KB)
