using Arduinos and emitter for wormholes
I've been researching wormholes and there prospect that they might be able to be used for portals. I was thinking that Arduino micro controllers and emitters could be used to make a wormhole big enough to travel trough. i was wonder how could program the emitter to fire a projectile portal for this type of technology if the reactor flows trough the emitter but has to make a projectile portal to fire out trough the optics.
What have you tried and how did it work?
Paul
Were you planning on wormhole time travel, space travel, or both?
what is used is a control box for the handheld device quad display on there ,push button for the trigger a telsa globe for the reactor to flow trough the emitter the emitter chip had opitcs but needed to be program to create portal bolt that could open up the wormhole or fire a wormhole on to any surface
Tesla coils are often used.
didnt mean telsa globe i ment a plasma globe that flows trough the emitter its like a handheld device
Clearly not a real Arduino Q.
So Have at it in Bar sport.
ryantech77:
I can't quite visualize this. Can you post a photo.
...R
PS ... I already have a tinfoil hat.
