Using AREF voltage output?
I am designing a simple circuit to condition a pressure sensor input to an Arduino clone. I would like to use the internal 1.1V analog reference in my circuit. I haven't found any specifications on using the AREF pin in this way (current limit). From my reading the internal reference should be more stable than Vcc even if it is not exactly 1.1V. The circuit will drop this voltage across a 25-50K pot so the current will be really small. Any suggestions?
John
DP Sensor V3.pdf (19 KB)
The [u]ATmega datasheet[/u] says you should NOT do that!
24.5.2 ADC Voltage Reference
The reference voltage for the ADC (VREF) indicates the conversion range for the ADC. Single ended channels that
exceed VREF will result in codes close to 0x3FF. VREF can be selected as either AVCC, internal 1.1V reference, or
external AREF pin.
AVCC is connected to the ADC through a passive switch. The internal 1.1V reference is generated from the internal
bandgap reference (VBG) through an internal amplifier. In either case, the external AREF pin is directly connected
to the ADC, and the reference voltage can be made more immune to noise by connecting a capacitor between the
AREF pin and ground. VREF can also be measured at the AREF pin with a high impedance voltmeter. Note that VREF is a high impedance source, and only a capacitive load should be connected in a system.
If the user has a fixed voltage source connected to the AREF pin, the user may not use the other reference voltage
options in the application, as they will be shorted to the external voltage. If no external voltage is applied to the
AREF pin, the user may switch between AVCC and 1.1V as reference selection. The first ADC conversion result
after switching reference voltage source may be inaccurate, and the user is advised to discard this result.
But I doubt you'll permanently damage the chip, so you might want to go-ahead and try it...
