Using arrays with two variables
Hi all,
Hoping someone can help me (a novice coder) out with arrays.
I’m wanting to call/display values based off a profile and switch number - in essence:
const int profile0[8]= {110.00, 120.00, 130.00, 140.00, 150.00, 160.00, 170.00, 180.00};
const int profile1[8]= {110.10, 120.10, 130.10, 140.10, 150.10, 160.10, 170.10, 180.10};
const int profile2[8]= {110.20, 120.20, 130.20, 140.20, 150.20, 160.20, 170.20, 180.20};
I wish to be able to switch between ‘profiles’ and then display the data within.
Normally arrays are in the form arrayName[int] for this but I want to be able to have something like
profile[profileNumber][switchNumber] - is that even possible somehow??
I could then use a loop/sub-routine like this: (made more complicated by the fact I want to add flexibility to truncate data based off a limit set by a variable ‘sensorsUsed’)
void printProfileSettings(){
    Serial.print("Profile ");
    Serial.print(profileNumber);
    Serial.println(" set");
    for (switchNumber = 0; switchNumber < sensorsUsed; switchNumber++){
      if (switchNumber < (sensorsUsed-2)){
      Serial.print(profile[profileNumber][switchNumber]);
    if (switchNumber == (sensorsUsed-1){
      Serial.println(profile[profileNumber][switchNumber]);
BUT obviously that won’t work as the issue is arrayName[int][int] which can’t happen.
Can anyone give me some tips or ideas please :slight_smile:
Thanks
I suspect you may have also misunderstood the term “int”.
They don’t hold fractions.
It’s a contraction of “integer”
const int profile [][8] = {{....},{....}
Matra:
BUT obviously that won't work as the issue is arrayName[int][int] which can't happen.
Why do you think it can't happen? It's just a two-dimensional array. They're very common.
const int SensorsUsed = 8;
const float Profiles[][SensorsUsed] =
  {110.00, 120.00, 130.00, 140.00, 150.00, 160.00, 170.00, 180.00},
  {110.10, 120.10, 130.10, 140.10, 150.10, 160.10, 170.10, 180.10},
void printProfileSettings(int profileNumber)
  for (int switchNumber = 0; switchNumber < SensorsUsed; switchNumber++)
    Serial.print(Profiles[profileNumber][switchNumber]);
    if (switchNumber < SensorsUsed - 1)
      Serial.print(", ");
johnwasser:
const float Profiles[SensorsUsed] =
  Serial.print(“Profile “);
  Serial.println(” set”);
      Serial.print(", ");
Got it!
I see where I went wrong, thanks :slight_smile:
(also thanks for improving the loop! I see what you did and it’s way more efficient that what I did)
