Using arrrays, for loop, and digital write to make a 7-LED display from 9-0,with a red LED on, and 5-0 afterwards, with a green LED shimmering
The below short peice of code shows me desperately trying to make number 7 display, newboy here. Could anyone point out the fault?
int RLED = 5;
int GLED = 2 ;
int MYARRAY[]={0,0,0,0,1,1,0,1};
pinMode(13,OUTPUT);
for(int counter=0;counter<1;counter++);{
digitalWrite(RLED,0);
digitalWrite(GLED,1);
digitalWrite(13,MYARRAY[counter][0]);
Many issues here:
All outputs should be set to output before digitalwrite
Counter will always be zero.
The ; shouldn't be present here );{
The array is initialized as one dimensional and applied as two dimensional. This may be ok, but I doubt whether you are aware.
Could you add a wiring scheme?
To me it is not at all clear what you are trying to accomplish...
//Using arrrays, for loop, and digital write to make a
//7-LED display from 9-0,with a red LED on, and 5-0
//afterwards, with a green LED shimmering
int RLED = 5;
int GLED = 2 ;
byte GLEDValue = 0;
/*  a
  f   b
    g
  e   c
    d
int SevenSegPins[7] = {3, 4, 6, 7, 8, 9, 10};
int Numbers[10][7] = {
  //a b c d e f g
   {0,0,0,0,0,0,1}, //0
   {1,0,0,1,1,1,1}, //1
   {0,0,1,0,0,1,0}, //2
   {0,0,0,0,1,1,0}, //3
   {1,0,0,1,1,0,0}, //4
   {0,1,0,0,1,0,0}, //5
   {0,1,0,0,0,0,0}, //6
   {0,0,0,1,1,1,1}, //7
   {0,0,0,0,0,0,0}, //8
   {0,0,0,0,1,0,0} //9
   pinMode(RLED,OUTPUT);
   pinMode(GLED,OUTPUT);
   for (int sevSeg=0; sevSeg < 7; sevSeg++){
       pinMode(SevenSegPins[sevSeg],OUTPUT);
  digitalWrite(RLED,1);
  byte GLEDValue = 0;
  digitalWrite(GLED,GLEDValue);
  for(int counter=9;counter>=0;counter--){
       digitalWrite(SevenSegPins[sevSeg],Numbers[counter][sevSeg]);
  for(int counter=5;counter>=0;counter--){
    for (int blinktimes = 0; blinktimes < 10; blinktimes++){
       GLEDValue = !GLEDValue;
       delay(100);
Thanks for the reply man, our teacher have just taught us 2D. To be fair, the question was indeed quite unclear. Pleasure to meet you!
Thanks for the super straightforward code man. Quite confused by the large amounts of variables tho, esp for the last bit, you didn't seem to use blinktimes at all? I also don't get GLEDValue =!GLEDValue, why does 0 not = 0 run?
That would explain it. :rofl:
Thanks by the way, haven't been here for a while.
