Using ATMEGA flash memory to log data
Hello,
I was hoping to use the Arduino’s own flash memory to log data from a sensor.
Is there any way I can do this? SRAM does not have enough memory for me to add data, and the PROGMEM attribute is only for constant data, I can’t declare a space of bytes reserved for one type of sensor, for instance, because later I cannot change this,.
Is there any way this can be done?
Thanks in advance
Yes, check this out http://forum.arduino.cc/index.php?topic=332191.0
Please let us know if you get it going the way you want and make a how-to guide.
