I purchased ATMEGA328 instead of ATMEGA328Ps. I was able to program the bootloader, using Minicore breadboard solution. However, when I now put that micro on the Uno, and I try to compile the example sketches (used known good ones to ensure everything is working), I get the error in the signature of the device. It expects the device on the UNO to be a 328P and I'm getting the signature of the 328.
I tried adding the 328 device to the boards.txt, but it is read only, and I can't figure out how to override its file protection.
The error message suggests I override the signature with -F option on the avrdude command, but I can't figure out where to add this option (looking through the avrdude config file, etc).
How can I add support for this micro on the UNO? Can I create another board.txt file that it can then use to tpass the "right" info to avrdude ? There must be a way.....
Thanks @sterretje, this is running on my personal PC, so I am the admin with full privileges, and I still can't seem to override the write protection! I had never run into that.
You are right, though. I was able to compile using the MiniCore 328 board as the target. So for now, I can work arouind the issue. However, the "right" solution, in my opinion, would be to add the board to the board.txt file --ie, an UNO with a ATMEGA328.
Any idea how to pass arguments to the avrdude when it is invoked from the arduinoISP sketch?
