Using atoi() to convert Serial data
I am working on a sketch that will allow me to control the Arduino from a computer using serial. I have written a program written in Processing that is going to provide the control interface, so I have full control over the Serial link. I have also written a simple sketch in Arduino to test. This sketch is based on the Blink and Serial.available examples. Basically I am just trying to change the blink delay rates using serial commands. Everything works great (I stuck a couple of println() calls in there so I could see what was going on) except when I try to convert my char array (string) to an int. I did some research on the atoi() function, and realize I need to insert a null character at the end of the array for it to be a valid string, and allow atoi() to convert it into an int. I did that - but the function is still returning zero, which from my research means that it is trying to convert an invalid string.
I am stumped...What am I missing?
#define greenLed 7
#define yellowLed 6
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
int greenDelay = 200;
int yellowDelay = 1000;
char tempChar[10];
int i;
  // initialize serial:
  pinMode(greenLed, OUTPUT);
  pinMode(yellowLed, OUTPUT);
  // print the string when a newline arrives:
  if (Serial.available()>0) serialEvent();
  if (stringComplete) {
    Serial.println(inputString);
    switch (inputString.charAt(0)){
      case 'A':
      for(i=1 ; i<inputString.length() ;i++){
        tempChar[i] = inputString.charAt(i);
        Serial.println(tempChar[i]);
      tempChar[inputString.length()] = '\0';
      greenDelay = atoi(tempChar);
      Serial.print("New Green Delay Value:");
      Serial.println(greenDelay);
      case 'B':
      for( i=1 ; i<inputString.length() ; i++){
      yellowDelay = atoi(tempChar);
      Serial.println(tempChar[0]);
      Serial.print("New Yellow Delay Value:");
      Serial.println(yellowDelay);
      default:
      Serial.println("Invalid Command");
    inputString = "";
    blinkGreen(greenDelay);
    blinkYellow(yellowDelay);
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
void blinkGreen (int x){
 digitalWrite(greenLed, HIGH);   // set the LED on
  delay(x);              // wait for a second
  digitalWrite(greenLed, LOW);    // set the LED off
void blinkYellow (int x){
 digitalWrite(yellowLed, HIGH);   // set the LED on
  digitalWrite(yellowLed, LOW);    // set the LED off
If you define a serialEvent() method, it will be called automatically. You don't need to, on 1.0 and later, and shouldn't.
What is in tempChar[0]? When you copy the data from inputString[n], it should go into tempChar[n-1]. (You used i, but the forum software interprets [ i ] as italics, so I used n.)
PaulS
Thank You - that is exactly what I missed.
I was running this sketch on a Sanguino, which is only compatible up to 023. I had to find a way to call seriallEvent(), this is working now, but realize I will need to take this if statement out if I want to run this sketch on 1.0.
Thanks for your help!!
