Using attachInterrupt to halt a function using a switch
I have made a simple LED array contained inside a SparkFun box. I have also created multiple functions that light each LED up in different patterns. All LEDs are connected to individual digital pins on my SparkFun Redboard (basically an Arduino Uno). I have also added a toggle switch to the top of the box for power. Currently, my code uses an if statement in the loop to determine whether the switch is turned to on or off. When it is turned to on, each pattern function is called three times, which takes about a minute or so to go through every pattern. What I can't seem to figure out is how to code the switch so that when I turn it to the off position in the middle of a pattern, all of the lights turn off. Right now, if I toggle the switch to off in the middle of the pattern sequence, the program simply waits for the last pattern to complete and then turns off. Of course, this isn't like a real power switch. I have been trying to use the attachInterrupt function, but have had no success. PLEASE HELP! :cry: :cry: :cry:
The attached code has my failed attachInterrupt code commented out. The uncommented code runs properly besides the delayed 'turn off' from the switch.
LED_box.ino (6.34 KB)
Pertaining to Delta_G's advice, look at the "Blink without delay" and "How to do several things at the same time" links:
forum.arduino.cc/index.php?topic=384198.0
best,
Michael
Edit: BTW, some of the links on that page will lead you to Nick Gammon's site. It's worth spending some time there.
--M
int REDpins[] = {2, 3, 4};
int GREENpins[] = {5, 6, 7};
int BLUEpins[] = {8, 9, 10};
int YELLOWpins[] = {11, 12, 13};
int switchPin = 0;
//volatile boolean power = false;
  int index;
  for (index = 0; index <= 2; index++) {
    pinMode(REDpins[index], OUTPUT);
    pinMode(GREENpins[index], OUTPUT);
    pinMode(BLUEpins[index], OUTPUT);
    pinMode(YELLOWpins[index], OUTPUT);
  pinMode(switchPin, INPUT);
  //attachInterrupt(switchPin, powercontrol, CHANGE);
  if (digitalRead(switchPin) == LOW) {
    wave();
    wave();
    steppingstone();
    steppingstone();
    colors();
    colors();
  else if (digitalRead(switchPin) == HIGH) {
    delay(5);
//  if (power == true) {
//    wave();
//    wave();
//    steppingstone();
//    steppingstone();
//    colors();
//    colors();
//  else if (power == false) {
//    delayMicroseconds(5);
//void powercontrol() {
//  if (digitalRead(switchPin) == LOW) {
//    power = true;
//  else if (digitalRead(switchPin) == HIGH) {
//    power = false;
void wave() {
  int index;
  int delayTime = 100;
  //turn RED pins on
    digitalWrite(REDpins[index], HIGH);
    delay(delayTime);
  //turn GREEN pins on
    digitalWrite(GREENpins[index], HIGH);
    delay(delayTime);
  //turn BLUE pins on
    digitalWrite(BLUEpins[index], HIGH);
    delay(delayTime);
  //turn YELLOW pins on
    digitalWrite(YELLOWpins[index], HIGH);
    delay(delayTime);
  //turn RED pins off
    digitalWrite(REDpins[index], LOW);
    delay(delayTime);
  //turn GREEN pins off
    digitalWrite(GREENpins[index], LOW);
    delay(delayTime);
  //turn BLUE pins off
    digitalWrite(BLUEpins[index], LOW);
    delay(delayTime);
  //turn YELLOW pins off
    digitalWrite(YELLOWpins[index], LOW);
    delay(delayTime);
  for (index = 2; index >= 0; index--) {
    delay(delayTime);
  //turn BLUE pins on
    delay(delayTime);
    delay(delayTime);
  //turn RED pins on
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
  //turn RED pins off
    delay(delayTime);
void steppingstone() {
  int index;
  int delayTime(100);
  //turn RED pins on then off
    delay(delayTime);
  //turn GREEN pins on then off
    delay(delayTime);
  //turn BLUE pins on then off
    delay(delayTime);
  //turn YELLOW pins on then off
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
void colors() {
  int index;
  int delayTime(500);
  delay(delayTime / 2);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
Maybe this will help you.
If you want to use an interrupt In Arduino UNO you most use the pins below.
Board Digital Pins Usable For Interrupts
Uno, Nano, Mini, other 328-based 2, 3
Better still would be to show how not to use an interrupt where an interrupt is not appropriate,
Delta_G, I am confused how I make the pattern functions non-blocking. After each LED change, is that when I check the status of the button?
Absolutely right.
rzouk:
Yes. But that does NOT mean adding dozens of pieces of code into your program to check the button status.
Your code should be designed so it just moves one step through the sequence everytime loop() repeats. Look at how the servo operates in Several Things at a Time
...R
