When I had set the camera up just by itself all I had to put in the address was 10.0.1.75 and it took me to a page with a still camera image with a bunch of settings and a start streaming button. When the Start Streaming button was pushed the video started playing and the button changed names to stop streaming. However the address at that time was 10.0.1.75 port 80 not 81 as shown on the above printout. I will post my code here;
#include "esp_camera.h"
#include <WiFi.h>
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
#include <Esp32WifiManager.h>
#include <SPI.h>
#include <WebServer.h>
#include <time.h>
#include <AutoConnect.h>
#include <WiFiClient.h>
//#include <BlynkSimpleEsp32_WM.h>
#include <BlynkSimpleEsp32.h>
int pinValue4;
int pinValue8;
int LED;
int pin_d0;
//Blynk
//CAMERA
static const char AUX_TIMEZONE[] PROGMEM = R"(
"title": "TimeZone",
"uri": "/timezone",
"menu": true,
"element": [
"name": "caption",
"type": "ACText",
"value": "Sets the time zone to get the current local time.",
"style": "font-family:Arial;font-weight:bold;text-align:center;margin-bottom:10px;color:DarkSlateBlue"
"name": "timezone",
"type": "ACSelect",
"label": "Select TZ name",
"option": [],
"selected": 10
"name": "newline",
"type": "ACElement",
"value": "
"name": "start",
"type": "ACSubmit",
"value": "OK",
"uri": "/start"
typedef struct {
const char* zone;
const char* ntpServer;
int8_t tzoff;
} Timezone_t;
static const Timezone_t TZ[] = {
{ "Europe/London", "europe.pool.ntp.org", 0 },
{ "Europe/Berlin", "europe.pool.ntp.org", 1 },
{ "Europe/Helsinki", "europe.pool.ntp.org", 2 },
{ "Europe/Moscow", "europe.pool.ntp.org", 3 },
{ "Asia/Dubai", "asia.pool.ntp.org", 4 },
{ "Asia/Karachi", "asia.pool.ntp.org", 5 },
{ "Asia/Dhaka", "asia.pool.ntp.org", 6 },
{ "Asia/Jakarta", "asia.pool.ntp.org", 7 },
{ "Asia/Manila", "asia.pool.ntp.org", 8 },
{ "Asia/Tokyo", "asia.pool.ntp.org", 9 },
{ "Australia/Brisbane", "oceania.pool.ntp.org", 10 },
{ "Pacific/Noumea", "oceania.pool.ntp.org", 11 },
{ "Pacific/Auckland", "oceania.pool.ntp.org", 12 },
{ "Atlantic/Azores", "europe.pool.ntp.org", -1 },
{ "America/Noronha", "south-america.pool.ntp.org", -2 },
{ "America/Araguaina", "south-america.pool.ntp.org", -3 },
{ "America/Blanc-Sablon", "north-america.pool.ntp.org", -4},
{ "America/New_York", "north-america.pool.ntp.org", -5 },
{ "America/Chicago", "north-america.pool.ntp.org", -6 },
{ "America/Denver", "north-america.pool.ntp.org", -7 },
{ "America/Los_Angeles", "north-america.pool.ntp.org", -8 },
{ "America/Anchorage", "north-america.pool.ntp.org", -9 },
{ "Pacific/Honolulu", "north-america.pool.ntp.org", -10 },
{ "Pacific/Samoa", "oceania.pool.ntp.org", -11 }
#if defined(ARDUINO_ARCH_ESP8266)
ESP8266WebServer Server;
#elif defined(ARDUINO_ARCH_ESP32)
WebServer Server;
#endif
AutoConnect Portal(Server);
AutoConnectConfig Config; // Enable autoReconnect supported on v0.9.4
AutoConnectAux Timezone;
void rootPage() {
String content =
"<html>"
"<head>"
"<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">"
"<script type=\"text/javascript\">"
"setTimeout(\"location.reload()\", 1000);"
"</script>"
"</head>"
"<body>"
"<h2 align=\"center\" style=\"color:blue;margin:20px;\">Hello, world</h2>"
"<h3 align=\"center\" style=\"color:gray;margin:10px;\">{{DateTime}}</h3>"
"<p style=\"text-align:center;\">Reload the page to update the time.</p>"
"<p></p><p style=\"padding-top:15px;text-align:center\">" AUTOCONNECT_LINK(COG_24) "</p>"
"</body>"
"</html>";
static const char *wd[7] = { "Sun","Mon","Tue","Wed","Thr","Fri","Sat" };
struct tm *tm;
time_t t;
char dateTime[26];
t = time(NULL);
tm = localtime(&t);
sprintf(dateTime, "%04d/%02d/%02d(%s) %02d:%02d:%02d.",
tm->tm_year + 1900, tm->tm_mon + 1, tm->tm_mday,
wd[tm->tm_wday],
tm->tm_hour, tm->tm_min, tm->tm_sec);
content.replace("{{DateTime}}", String(dateTime));
Server.send(200, "text/html", content);
void startPage() {
// Retrieve the value of AutoConnectElement with arg function of WebServer class.
// Values are accessible with the element name.
String tz = Server.arg("timezone");
for (uint8_t n = 0; n < sizeof(TZ) / sizeof(Timezone_t); n++) {
String tzName = String(TZ[n].zone);
if (tz.equalsIgnoreCase(tzName)) {
configTime(TZ[n].tzoff * 3600, 0, TZ[n].ntpServer);
Serial.println("Time zone: " + tz);
Serial.println("ntp server: " + String(TZ[n].ntpServer));
// The /start page just constitutes timezone,
// it redirects to the root page without the content response.
Server.sendHeader("Location", String("http://") + Server.client().localIP().toString() + String("/"));
Server.send(302, "text/plain", "");
Server.client().flush();
Server.client().stop();
void startCameraServer();
Serial.setDebugOutput(true);
String Label;
char auth[] = "un0EpGjDyoekUrLHey8P9JTL9K6ukC-G";
byte pinState = LOW;
pinMode(14,OUTPUT);
digitalWrite(14,LOW);
int LED = 14;
pinMode(LED,OUTPUT);
digitalWrite (LED,LOW);
WidgetLED led1(V6);
led1.off();
led1.setValue(0);
//String pinValue9 = "g";
// Enable saved past credential by autoReconnect option,
// even once it is disconnected.
Config.autoReconnect = true;
Config.hostName = "FloWT2";
Portal.config(Config);
// Load aux. page
Timezone.load(AUX_TIMEZONE);
// Retrieve the select element that holds the time zone code and
// register the zone mnemonic in advance.
AutoConnectSelect& tz = Timezone["timezone"].as<AutoConnectSelect>();
tz.add(String(TZ[n].zone));
Portal.join({ Timezone }); // Register aux. page
// Behavior a root path of ESP8266WebServer.
Server.on("/", rootPage);
Server.on("/start", startPage); // Set NTP server trigger handler
Serial.println("Creating portal and trying to connect...");
// Establish a connection with an autoReconnect option.
if (Portal.begin()) {
Serial.println("WiFi connected: " + WiFi.localIP().toString());
Serial.println(WiFi.hostname());
Serial.println(WiFi.getHostname());
#endif
camera_config_t config;
//pin configuration is here but took out because of limited character length.
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
//initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1);//flip it back
s->set_brightness(s, 1);//up the blightness just a bit
s->set_saturation(s, -2);//lower the saturation
//drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
delay(3000);
delay(2000);
Blynk.syncAll();
Blynk.config("un0EpGjDyoekUrLHey8P9JTL9K6ukC-G");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
Portal.handleClient();
Blynk.run();
I am powering the ESP32-CAm with 5v FIDI as didn’t work too well at 3.3v. I also tried it connected to power source at 500mA 3.3v. Still didn’t work. I could try 500mA at 5v to see it that helps.
Anyway I hope someone can help with this last step.
