Hi all,
I have setup inexpensive RF 433MHz modules for transferring some sensor data through VirtualWire library...
I want to be able to send the received data (through RF-virtualwire) via bluetooth module (Using RX, TX pins on arduino with Serial.Write()) to my laptop. For some strange reason I am not able to receive anything on my laptop.
I am using HC-05 bluetooth module with 9600 baud rate. Virtualwire is working with 2000 bps. The sample code is something like
#include <VirtualWire.h>
Serial.Write("Setup");
vw_set_ptt_inverted(true);
vw_setup(2000); // Bits per sec
vw_rx_start();
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
Serial.write("Got: ");
for (i = 0; i < buflen; i++)
Serial.write(buf[i], HEX);
Serial.write(" ");
Strange thing is I am not even receiving the "Setup" string sent! let alone the sensor readings
Any help/insights is greatly appreciated.
