using Blynk and Thingspeak in same sketch - multiple server issue?
i have a house ventilation sketch that uses 3 DHT22 sensors placed in 3 air inlets to work out which vent to open to duct to my rooms.
i want to log the readings to Thingspeak and also see them on my smartphone using Blynk.
i slowly combined the sketches and have the ventilation controller, the Blynk app code and Thingspeak code all working but only like this:
  1. ventilation controller + Blnk code
  2. ventilation controller + Thingspeak code
but not like:
  1. ventilation controller code + Blynk code + Thingspeak code
when i try to combine, the Blynk app stops working, but the Thingspeak still works.
is it something to do with the WiFi client code?
how can i fix this?
here is the code: <<too large? over 9000?>>
(if i comment out the void ThingspeakCode() section, the Blynk code works)
any other comments on code welcome - i am totally new at this!!!
attached is a Blynk screenshot
attached is the code, in .txt
how can i add code inline if it is over 9000 char?
sorry.
Forgot to add, this is on an esp8266-12 using 1.6.4 ide
Thanks for posting.
First of all, you are initializing WiFi 2 times, which is not good for sure.
Second, could you explain how do you use thingspeak? There is a Widget in Blynk app called History Graph, which can plot up to 4 data streams.
blynk:
Thanks for posting.
thanks for replying!
ok, i thought it is an issue,
how do i connect with two servers in one sketch?
can i use a different name, like clientBlynk and clientThingspeak?
how can i implement this?
it seems the blynk library has the client references, so do i need to change the Blynk library?
i use Thingspeak for data-logging (i.e. download all the collected & stored data to .csv file for analysis), and Blynk for visualisation (i.e. a “dashboard”), and eventually alerts and controls.
also - Thingspeak is available on any internet enabled device, so i can check it anywhere.
Thingspeak and Blynk are intended for very different purposes, so i would like both to function together…
i have found this by SurferTim:
but since the begin.Blynk library seems to have the server stuff in it i am not sure where to start re-coding it.
or is the SurferTim post not relevant?
so it is actually a multiple client issue? not multiple server?
I think I'm making a bit of progress...
Hi Wareemba - were you able to get this working? I have the same question and would like the same setup for the same reasons - that the data on ThingSpeak can be accessed on any device through a browser while I can quickly build and see visualization via Blynk on my phone. If you got it working, please share! :slight_smile:
