It is self resolved.
The solution is to change the I2C clock speed at mlx90614.
Both sensors now output the correct values as below.
IR=6772, BPM=0.80, Avg BPM=0 No finger?
Ambient = 28.19C Object = 25.81C
Ambient = 82.74F Object = 78.46F
I looked up various information on the Internet.
I found an article about lowering the I2C clock speed as a countermeasure to fix the value at mlx90614.
I tried a method of dynamically adjusting the frequency before and after the I2C communication part of the Adafruit library source code "Adafruit_MLX90614.cpp" and it worked.
Adafruit_MLX90614.cpp around line 130,
uint16_t Adafruit_MLX90614::read16(uint8_t a) {
uint8_t buffer[3];
buffer[0] = a;
Wire.setClock(50000);
// read two bytes of data + pec
bool status = i2c_dev->write_then_read(buffer, 1, buffer, 3);
if (!status)
return 0;
Wire.setClock(100000);
// return data, ignore pec
return uint16_t(buffer[0]) | (uint16_t(buffer[1]) << 8);
