Using Both NO and NC connector on relay board
Guys,
I have a number of Honeywell Solenoids that i wish to use to control hydronic zones in my house - Honeywell VC6012 - link to the manual here https://www.oeg.net/en/download/get/type/article/file/RU4yUjkwMTEuUERG
They are 240vac operated and appear to be "latching" solenoids in that when current is supplied to one wire they are driven to be closed - and stay that way regardless of whether the current is removed. When applied to a different connector - the motion is then reversed and they go back to the previous position (in this case open and closing a water valve)
Would it be valid using one of the standard 5v Arduino relay modules (such as http://www.icstation.com/channel-self-lock-relay-module-arduino-p-4926.html) to drive both sides of this solenoid from a single relay - with one wire going to the NO and the other to the NC - or am i breaking some rules here i am unaware of ?
regards
Craig
Fig. 4
Put your relay instead SPST
Hi Craig,
Wait.. Exactly which Honeywell controller do you have??
Red label 220V ??
The (PDF) Figure 3 controller or the Fig. 4 controller??
Terry - sorry thought i had put enough detail.
It is the red label unit - 2 port only - with 6 pin molex connector for power/control
3 wires into the unit - brown, black and blue
Figure 3 seems to match up
regards
Craig
