Using BTT6030 24V
Hello All,
Is anyone already use BTT6030 24V Profet from Infineon ??
24V Infineon
This board is compatible with Arduino but when you ask Infineon for Arduino Samples ... they said it's compatible but we do not provide Arduino software ....
-- Strange Compatibility ... but if anyone has already worked with this shield ... I'm very interested ...
I would like to use it in a very simple case : use Infineon Outputs to control a 24 V Led Light from PATLITE.
What is your experience with the Arduino.
If you can turn a LED on/off with a pin, then you should also be able to turn a channel of this board on/off.
The datasheet (pin use) is very clear. It even has a connection diagram.
Leo..
