Thanks again for the answers. I've been working on the code trying to streamline it even more.
To answer your questions - I found out the huge delay came from the HX711. When I remove scale.get_units(10); everything runs smooth.
For now my only fix was to limit the read from the HX711 by wrapping it inside a counter.
It's not in any sense perfect - So i'm still very open to ideas and suggestions.
I've attached code below.
//Compatible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
#include <HX711.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 2;
const int LOADCELL_SCK_PIN = 3;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define NAVBAR_X_COORD 57 // X position for navbar locataion
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
HX711 scale;
const int LeftButtonPin = 6;
const int CenterButtonPin = 7;
const int RightButtonPin = 5;
int LeftButtonState = 0;
int CenterButtonState = 0;
int RightButtonState = 0;
double currentbrewTime = 0;
double brewTime = 27;
float getpercent;
float barwidth;
float currentGrams;
float targetGrams = 308.0f;
float gramsGetPercent;
float gramsBarWidth;
float readingfromscale;
int currentScreen = 1;
// 1 = Menu 2 = Brew 3 = Time settings 4 = Tare Done 5 = End
int menuItem = 1;
int countdown = 1;
int tempcountdown;
//initiate buttons
pinMode(LeftButtonPin, INPUT);
pinMode(CenterButtonPin, INPUT);
pinMode(RightButtonPin, INPUT);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for OLED
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.clearDisplay();
drawScreens();
display.display();
// listen on serial for scale HX711
Serial.begin(57600);
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
// Calibrate the scale
scale.set_scale(1860);
scale.tare();
//read button states
LeftButtonState = digitalRead(LeftButtonPin);
CenterButtonState = digitalRead(CenterButtonPin);
RightButtonState = digitalRead(RightButtonPin);
buttonLogic();
if (currentScreen == 2) {
drawScreens();
display.display();
if (scale.wait_ready_timeout(1000)) {
countdown = countdown-1;
if (countdown == 0) {
countdown = 60;
readingfromscale = scale.get_units(10);
drawScreens();
display.display();
delay(100);
void buttonLogic(){
//if on menu and left is pressed
if (LeftButtonState == HIGH && currentScreen == 1) {
if (menuItem == 1){
menuItem = 3;
menuItem = menuItem-1;
drawScreens();
display.display();
//if on menu and center is pressed
if (CenterButtonState == HIGH && currentScreen == 1 && currentScreen == 1) {
if (menuItem == 3){
menuItem = 1;
menuItem = menuItem+1;
drawScreens();
display.display();
// if on brew menu and pressed
if (RightButtonState == HIGH && currentScreen == 1 && menuItem == 1) {
currentScreen = 2;
drawScreens();
display.display();
// if on tare menu and pressed
if (RightButtonState == HIGH && currentScreen == 1 && menuItem == 2) {
scale.tare();
drawScreens();
display.display();
void drawScreens(){
// SCREEN MENU
if (currentScreen == 1){
if (menuItem == 1){
drawMainMenu(1);
drawNavMenu();
if (menuItem == 2){
drawMainMenu(2);
drawNavMenu();
if (menuItem == 3){
drawMainMenu(3);
drawNavMenu();
display.setTextSize(1);
if (menuItem == 2){ display.setTextColor(BLACK);} else {display.setTextColor(WHITE);}
display.setCursor(90,24);
display.print(readingfromscale);
display.display();
// SCREEN BREWING
if (currentScreen == 2){
display.setCursor(1,1);
display.setTextSize(2);
display.print("Brewing");
display.setCursor(105,6);
display.print(targetGrams);
display.setCursor(45,NAVBAR_X_COORD);
display.print("STOP");
//draw bar
currentGrams = readingfromscale;
getpercent = currentGrams / targetGrams * 100;
barwidth = 128.0f / 100.0f * getpercent;
currentbrewTime = currentbrewTime +1;
display.drawRect(0,19, SCREEN_WIDTH, 16, WHITE);
display.fillRect(0,19, barwidth, 16, WHITE);
display.setCursor(20,40);
display.print(currentbrewTime);
display.display();
//if grams is the same as targetgrams
if (currentGrams >= targetGrams) {
currentScreen = 5;
drawScreens();
display.display();
// SCREED DONE
if (currentScreen == 5){
display.print("Complete");
display.setCursor(1,20);
display.print("MENU");
void drawMainMenu(int no){
if (no == 1){
display.fillRect(0,0, SCREEN_WIDTH, 16, WHITE);
if (no == 2){
display.fillRect(0,19, SCREEN_WIDTH, 16, WHITE);
if (no == 3){
display.fillRect(0,38, SCREEN_WIDTH, 16, WHITE);
if (no == 1){ display.setTextColor(BLACK);} else {display.setTextColor(WHITE);}
display.print("Brew");
if (no == 2){ display.setTextColor(BLACK);} else {display.setTextColor(WHITE);}
display.print("Tare");
if (no == 3){ display.setTextColor(BLACK);} else {display.setTextColor(WHITE);}
display.setCursor(1,39);
display.print("Time");
void drawNavMenu(){
display.setCursor(0,NAVBAR_X_COORD);
display.print("UP");
display.print("DOWN");
display.setCursor(90,NAVBAR_X_COORD);
display.print("SELECT");
