As per Arduino reference,Byte is a memory location of 8bits and it can take values ranging 0-255.
Qn 1 I tried to give character value to a byte variable (eg byte val='a' and print it using Serial.print(val);, I was able to print the value as "a"; but when I tried to give a integer value to the byte variable(byte val=20;) I was not able to print it using the statement Serial.print(val). Instead of that I have to use the statement Serial.print(val, DEC) why is this so?
Qn2: Is there a way I can store value in an integer variable (eg int n=65;) and print the character 'a'(since ASCII 65= character a) using the integer variable n with the help of Serial.print(n);
Reference? I don't believe that Byte is defined anywhere in the Arduino documentation. byte, yes. Byte, no.
If the values you want to store represent characters, why do you want to waste the extra byte storing them in ints, instead of bytes?
byte is a datatype - it is an unsigned 8 bit value, so when such a value is stored in memory it takes a byte, but a value doesn't always get to memory (intermediate results for instance).
Casts enable one value to be treated as if a different type. For instance:
print ((char) n) ;
will treat the value of n as a char (shortening it to 8 bits in the process, but not affecting the original variable n).
