Using c#
Hey everyone, I want to make a windows form application with c# and use it to program my led cube. So I want to edit an arduino sketch on my application and then upload it throug visual studio with a button click. Is it possible? If so, then how to make it happen?
You should be able to write a C# program that calls the Arduino IDE to compile and upload the program. I did this with Python in this link and a more extensive version here
...R
Ok, I hope I'll find my way to make it work. Thx
Having a C# application create the data makes sense. Having it create the program that contains and uses the data does not. Why do you want to do that? At a minimum, you should start with a program that defines the data to use, and sends that data to the Arduino. Only when you know that the Arduino can use the data should you try to do more.
