Hello,
I am fairly new to Arduino and electrics, so please excuse my incompetence. And I have tried looking for this specific setup on several forums, but none was found.
First of all: I am not powering anything from my car's battery. In my car, I have a charger outlet (cigarette type) which outputs 12V. Can I use this to power an LED Strip?
If I can, which kind of adapter would I need?
Basically, I want to do this: http://learn.adafruit.com/system/assets/assets/000/002/692/medium800/ledstripfet.gif?1353964350
But I only have an Arduino UNO, which doesn't have a 9V output pin. So I want to use my 12V output charger in my car instead.
The main thing I am stuck on is how to connect the strips to the Arduino with all the transistors with an external power supply? And, how do I connect the ground for the Arduino to the ground for the LED Strip?
Edit: I just found this, Female DC Power adapter - 2.1mm jack to screw terminal block : ID 368 : $2.00 : Adafruit Industries, Unique & fun DIY electronics and kits
Can I maybe use this to get a positive and ground wire from my car's 12V output?
