Hello, I am using a CC1101 module to receive RF signals from a transmitter I have installed in my home. I can receive values from the transmitter via the RF signals but I cannot get them to be stored on the SDCARD READER.
I am using an Arduino Mega as the microcontroller . The CC1101 and SDCARD READER share the same MISO, MOSI and SCK pins, but I used pin 9 and 10 as the CS pins of the CC1101 and SDCARD READER respectively.
If you have experienced this problem or know of a solution it would be great to hear it
Thanks
Can you provide a picture of the SD card module you are using, or a link to it?
If it's a microSD module with level translation, it may suffer from the typical defect of most such modules which is the failure of the module to release the MISO line when not selected.
Other possibilities would be wrong pins for SPI for the Mega, or some power supply issue.
