Using constant instead of serial.read()
Hi thogether,
I am new with arduino and try to send a constant number with an rfm69hw. For this I am using this Sparkfun Library: github.com/sparkfun/RFM69HCW_Breakout.
In the code you can send the message by Serial.read() but I want to send a constant value. This could be a number or a name.
I tried to set a char to A like:
char input = {'A'};
but it sends a couple of A´s like:
Node 26 ready
sending to node 1: [AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA]
no ACK received :(
So I was wondering how Serial.read() work inside but I couldn´t find something.
Is there a way to use a constant instead of Serial.read()?
  int val = analogRead(A2);
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input != '\r') // not a carriage return
      sendbuffer[sendlength] = input;
      sendlength++;
    // If the input is a carriage return, or the buffer is full:
    if ((input == '\r') || (sendlength == 61)) // CR or buffer full
      // Send the packet!
      Serial.print("sending to node ");
      Serial.print(TONODEID, DEC);
      Serial.print(": [");
      for (byte i = 0; i < sendlength; i++)
        Serial.print(sendbuffer[i]);
      Serial.println("]");
      // There are two ways to send packets. If you want
      // acknowledgements, use sendWithRetry():
      if (USEACK)
        if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
          Serial.println("ACK received!");
          Serial.println("no ACK received :(");
      // If you don't need acknowledgements, just use send():
      else // don't use ACK
        radio.send(TONODEID, sendbuffer, sendlength);
      sendlength = 0; // reset the packet
      Blink(LED,10);
Thanks a lot for your support!
Post the code you tried.
Do you want to send the message literally once or once any time some event happens ?
Sending it once should be easy. Put the code, or a call to the sending function in setup() instead of loop()
I have not used those wireless modules but this seems straightforward
and sends the first sendlength bytes from the array sendbuffer
To send a fixed message try this
char myTestMessage[] = "Hello World";
radio.send(TONODEID, myTestMessage, sizeof(myTestMessage));
...R
Edit to add [] - hope it's correct now
char myTestMessage = "Hello World";?
Hi UKHeliBob,
I tried it like this:
  if(val>1000)
  //if (Serial.available() > 0)
    //char input = Serial.read();
    char input = {'A'};
      sendlength++;
I press a button and want to send an A.
I also tried Robin2´s idea to. If I use an char it does work. But if I use an int it is working a bit :wink:
For "Hello World" it´s just sending [He].
Edit: With a long I can get 4 characters :wink:
UKHeliBob:
Thank you for pointing out my oversight - I have updated my earlier reply.
I must say I think it would have been more helpful for the OP if you had told him/her how it needed to be done.
...R
mcschiess:
You need to post the code that you tried - otherwise we have no idea what you actually did.
NOTE that there was a mistake in my Reply #2 - apologies for any confusion.
...R
Hi Robin2,
here is the code I´m using now. It´s stripped to the main things I need.
// RFM69HCW Example Sketch
// Send serial input characters from one RFM69 node to another
// Based on RFM69 library sample code by Felix Rusu
// http://LowPowerLab.com/contact
// Modified for RFM69HCW by Mike Grusin, 4/16
// This sketch will show you the basics of using an
// RFM69HCW radio module. SparkFun's part numbers are:
// 915MHz: https://www.sparkfun.com/products/12775
// 434MHz: https://www.sparkfun.com/products/12823
// See the hook-up guide for wiring instructions:
// https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide
// Uses the RFM69 library by Felix Rusu, LowPowerLab.com
// Original library: https://www.github.com/lowpowerlab/rfm69
// SparkFun repository: https://github.com/sparkfun/RFM69HCW_Breakout
// Include the RFM69 and SPI libraries:
#include <RFM69.h>
#include <SPI.h>
// Addresses for this node. CHANGE THESE FOR EACH NODE!
#define NETWORKID     0   // Must be the same for all nodes (0 to 255)
#define MYNODEID      26   // My node ID (0 to 255)
#define TONODEID      1   // Destination node ID (0 to 254, 255 = broadcast)
// RFM69 frequency, uncomment the frequency of your module:
#define FREQUENCY   RF69_433MHZ
// AES encryption (or not):
#define ENCRYPT       true // Set to "true" to use encryption
#define ENCRYPTKEY    "TOPSECRETPASSWRD" // Use the same 16-byte key on all nodes
// Create a library object for our RFM69HCW module:
RFM69 radio;
  // Open a serial port so we can send keystrokes to the module:
  Serial.print("Node ");
  Serial.print(MYNODEID,DEC);
  Serial.println(" ready");
  // Initialize the RFM69HCW:
  radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
  radio.setHighPower(); // Always use this for RFM69HCW
  // Turn on encryption if desired:
  if (ENCRYPT)
    radio.encrypt(ENCRYPTKEY);
 // SENDING
  if(val>1000)
    long myTestMessage = "A125";
        if (radio.sendWithRetry(TONODEID, myTestMessage, sizeof(myTestMessage)))
   delay(3000);
With the long I can have 4 Digits. I tried to use unsigned long to get more but it didn´t work.
This line
is suffering because of the mistake I had in Reply #2. Change it to
char myTestMessage[] = "A125";
In Reply #2 I had forgotten the [ ]
...R
It Works!!!!
Thanks a lot!
