It's on GitHub ESP8266_Weather_Station lots of really fun stuff you can do with weather reading in any of 40000 places on the map. Plus it has this handy SunMoonCalc you can give it your lon and lat and any time and it will tell you where the sun and moon are with respect to your position plus rise and set times so you can program your lights accordingly. I was hoping to be able to just use the calculation part in a Arduino module, but here's the gotcha, the whole thing is tightly linked to the esp board and unplugging all that is a hassle unless you know what you are doing. I got pretty far with it, but this time_t keeps causing problems of one sort or the other. And if you look at the cpp you see
the GitHub link gets you this leaving me lost because I don't know enough cpp:
timegm(3) - Linux man page
Name
timegm, timelocal - inverses of gmtime and localtime
Synopsis
#include <time.h>
time_t timelocal(struct tm *tm);
time_t timegm(struct tm *tm);
Feature Test Macro Requirements for glibc (see feature_test_macros(7)):
timelocal(), timegm(): _BSD_SOURCE || _SVID_SOURCE
Description
The functions timelocal() and timegm() are the inverses of localtime(3) and gmtime(3).
Conforming To
These functions are nonstandard GNU extensions that are also present on the BSDs. Avoid their use; see NOTES.
Notes
The timelocal() function is equivalent to the POSIX standard function mktime(3). There is no reason to ever use it.
For a portable version of timegm(), set the TZ environment variable to UTC, call mktime(3) and restore the value of TZ. Something like
#include <time.h>
#include <stdlib.h>
time_t
my_timegm(struct tm *tm)
time_t ret;
char *tz;
tz = getenv("TZ");
setenv("TZ", "", 1);
tzset();
ret = mktime(tm);
if (tz)
setenv("TZ", tz, 1);
unsetenv("TZ");
tzset();
return ret;
